Ratio test on series of n*e^(-n²)
5 replies · 2K views
nothingkwt
Ʃ ne(-n2)
I used the ratio test and wanted to know if the way I did it is correct or not
|a(n+1) / a(n)|
n+1 (e(-n2 -2n-1)) / n e(-n2)
Now e-n^2 cancels and we get
limn→∞ n+1/n * 1/(e2n)(e)
After you take the limits you get (1)*0 = 0 < 1 so it's convergent
nothingkwt said:
Ʃ ne(-n2)
|a(n+1) / a(n)|
(n+1) (e(-n2 -2n-1)) / (n e(-n2))
limn→∞ (n+1)/n * 1/((e2n)(e))
I have added your missing brackets. Aside from that your working is correct.
nothingkwt said:
Ʃ ne(-n2)
|a(n+1) / a(n)|
Sure, this works. But this sum looks almost purpose-built for the integral test. Try it (if you're allowed to use it).
I am actually but I just wanted to see if the ratio test worked
Thanks for the replies!
nothingkwt said:
Ʃ ne(-n2)
|a(n+1) / a(n)|
You really need to learn how to write in ASCII---in particular, you need to use brackets. Your first equation AS WRITTEN says
[tex]\left|\frac{a_{n+1}}{a_n}\right| = n +1 \frac{e^{-n^2-2n-1}}{n} e^{-n^2}.[/tex]
Your second formula reads as
[tex]\lim_{n \to \infty} n + \frac{1}{n} \frac{1}{e^{2n}} e[/tex]
I hope these are not what you mean. I hope you intended the first one to be
[tex]\left|\frac{a_{n+1}}{a_n}\right| = \frac{(n+1)e^{-n^2-2n-1}}{n e^{-n^2}},[/tex]
etc. To make sure this happens you need parentheses!
Yeah I'm not very good with ASCII I'm still learning how to use them.
