Rayleigh Scattering: Blue/Red Irradiance Ratio & Distance
The discussion focuses on the impact of distance on the blue/red irradiance ratio in Rayleigh scattering. It is established that when the sun is overhead, light travels through approximately 10-20 miles of atmosphere, allowing over 90% of light to reach the observer, resulting in a predominantly blue appearance. Conversely, during sunset, light travels through about 100 miles of atmosphere, scattering blue light more significantly and causing the sun to appear red or orange. The wavelength of blue light is approximately half that of red light, contributing to this phenomenon.
  • Understanding of Rayleigh scattering principles
  • Knowledge of light wavelengths (specifically blue and red)
  • Basic atmospheric science concepts
  • Familiarity with the geometry of the Earth and atmospheric thickness
  • Research the mathematical models of Rayleigh scattering
  • Explore the effects of atmospheric composition on light scattering
  • Study the relationship between light wavelength and scattering intensity
  • Investigate the impact of altitude on atmospheric light scattering
Students and professionals in atmospheric science, physicists studying light behavior, and educators teaching concepts of optics and environmental science.
e101101
General question
I is prop to λ**(-4)
Hi everyone, does the scattering irradiance ratio between blue/red change with distance with Rayleigh scattering?
I would think that it would remain generally constant..
A little info that should provide some helpful hints: When the sun is overhead, the light has about 10-20 miles of atmosphere to go through to reach you. The blue light gets scattered out more than the red light, but for both colors through this relatively short distance, greater than 90% of the light reaches the observer. When the sun is on the horizon, the light from the sun goes through perhaps 100 miles or more of atmosphere to reach the observer, because the atmosphere is a thin ring of about 20 miles thickness, on the circular (spherical earth) with a radius of about 4000 miles. ## \\ ## That should explain why the sun appears red or orange in a sunset, but looks white when viewed overhead. If you do a little arithmetic logic with this info, it should provide the answer to your question.## \\ ## (Note: blue light has a wavelength approximately half that of red light).
  • · Replies 0 ·
  • · Replies 57 ·
  • · Replies 0 ·
