What Does the Molar Composition in Crystal Synthesis Mean?
The discussion focuses on the interpretation of molar composition in crystal synthesis, specifically a reaction mixture consisting of 3.0 SiO2, 1.0 Al2O3, 0.1 NaCl, and 276 H2O. Participants clarify that the values represent moles of each compound, not molar fractions, and suggest that the high water volume indicates a significant dilution. The conversation concludes with a method for calculating the required amounts of each compound based on a fixed volume of water, demonstrating a practical application of the molar ratios.
  • Understanding of molar composition and stoichiometry
  • Familiarity with crystal synthesis processes
  • Knowledge of chemical reactions and molarity
  • Basic skills in performing ratio calculations
  • Research "Stoichiometry in crystal synthesis" for deeper insights
  • Learn about "Molarity and dilution calculations" for practical applications
  • Explore "Common conventions in chemical literature" to understand reporting standards
  • Investigate "Crystal growth techniques" to apply knowledge in experimental settings
Chemists, materials scientists, and students involved in crystal synthesis or those looking to understand the implications of molar compositions in chemical reactions.
ch3m
Hi guys,
I'm facing a problem.
I've read a paper where they tried to synthesise a crystal and they give the following reaction mixture molar composition:
3.0 SiO2
1.0 Al2O3
0.1 NaCl
276 H2O
What does it means?
It can't be the molar fraction since the sum of all the fraction must give 1 as result.
I guess that it should be the mol of each compound in solution, but that means that they have almost 5 L of water... am I right?
Chemistry news on Phys.org
That's how I would read the information.
No idea why they reported it this way, perhaps that's a convention used in such papers.
Thanks.
So can I take such values as a ratio??
I mean: 3.0:1.0:0.1:276
So if I fix a volume of 250 ml of water which means 13.877 mol, I need to divide the mols for 276 and then multiply for the ratio.
i.e. for Al2O3 --> 13.887*(1/276) and for NaCl 13.887*(0.1/276)
Right?
Looks OK.
