Read article on Pulsars, not clear how a sphere sources pole-only emission?
Pulsars emit radiation primarily from their magnetic poles due to strong magnetic fields that concentrate beams in these areas. The entire surface of a pulsar acts as a radio source, but the magnetic field restricts emissions to the poles, where the field is more curved, enhancing radiation output. The discussion raises questions about the beam's width and whether the radiation travels across the surface before reaching the poles. Observations suggest that the beams are narrow, influenced by the pulsar's rotation and magnetic configuration. Overall, the mechanisms of pulsar emissions highlight the complexities of astrophysical phenomena compared to biological systems.
ndvcxk
The pole still has extremely strong gravity, how can a sphere suddenly concentrate the radiation at the pole to be emitted there ?
As this is the only exit, should there not be a strong deformation ? How does the radiation make it to the pole, or, is the radiation we are getting only from the small pole area, the rest of the surface does not supply any ?
Thx, newbie!
Astronomy news on Phys.org
The pulsar has very strong magnetic fields which concentrate the beams and only allow them out at the poles.
Form the wiki article http://en.wikipedia.org/wiki/Pulsar
Thx for responding. In the picture the beam is way too thin, should the emission not be
way, way broader, (yet, we assume rotation is so fast).
1) Is there any possibility of replicating a magnetic-field controlled radiation emission from a sphere to form a so finely-focused beam ? (The absence of the field must be tube shaped !)
2) Is the radio-source "creeping along" the rest of the surface before it hits the poles ?
3) Or, are we only seeing the emission of the poles, nothing else.
(No, I don't think there are little green men, they would choose a pattern..)
I find astronomy, (compared to the lifesciences) highly, highly deductive, it's a bit
like a fantasy field...
The beam width would depend on the details of the magnetic field - not sure how you would measure it directly. If you knew the distance to the pulsar and measured th epulse width you could get the angle - but only if you knew the beam was aimed directly at you and so you were getting the full width. You can see the beam from an X-ray pulsar in a nebula where it lights up the surrounding gas.
The mechanism is different in different types of pulsar but basically the whole surface is a radio source. Stuff hitting the surface is turned into a plasma that is trapped by the field, the charged plasma moving in a curved field gives you radio emission. The magnetic field blocks the radio signal everywhere except at the poles. The field at the poles is also more curved which gives the most emission.
There are more weird objects to consider but they are also very simple in some sense. YOu have isolated objects on their own that you can study individually - much simpler than the interrelated mechanisms in biology.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
