Proof of Real Projective Plane Embedding in R4
  • Context: Graduate
  • Thread starter Thread starter rainwyz0706
    Plane
This discussion focuses on proving the existence of an embedding of the real projective plane P R2 in R4 using a continuous map defined by f: S2 → R4, where S2 is the unit sphere in R3. The mapping f is given by f(x, y, z) = (x² - y², xy, yz, zx). The goal is to demonstrate that this mapping induces a continuous map F: P R2 → R4, which is a homeomorphism onto a topological subspace of R4. Key insights include the use of equivalence classes and properties of the quotient topology to establish the proof.
  • Understanding of real projective planes and their properties
  • Familiarity with continuous mappings and homeomorphisms
  • Knowledge of quotient topology and equivalence relations
  • Basic concepts of topology, particularly compact and Hausdorff spaces
  • Study the properties of quotient maps in topology
  • Learn about continuous bijections and their implications in topology
  • Explore the concept of embeddings in higher-dimensional spaces
  • Investigate the relationship between compactness and homeomorphisms
This discussion is beneficial for mathematicians, topologists, and students studying advanced geometry, particularly those interested in projective geometry and embeddings in higher-dimensional spaces.
rainwyz0706
I'm working on a proof to show there exists an embedding of the real projective plane P R2 in R4.
The initial setup is as follows:
Let S2 denote the unit sphere in R3 given by S2 = {(x, y, z) ∈ R3 : x2 + y 2 + z 2 = 1}, and let
f : S2 → R4 be defined by f (x, y, z) = (x2 − y 2 , xy, yz, zx).
I'm trying to show that f determines a continuous map F: P R2 → R4 where P R2 is the real projective plane,
then show that F is a homeomorphism onto a topological subspace of R4 .
I think it's easy to see that f(x1,y1,z1)=f(x2,y2,z2) implies (x1,y1,z1)=+/-(x2,y2,z2). But I don't know how to figure out the whole proof completely. Could anyone please give me a hint? Any input is appreciated!
Hi, Rain:
If a map is constant ( has a constant value) on equivalence classes, then we
say that the map passes to the quotient, i.e., that we can work out a commutative
diagram with one of the sets being S/~ , where ~ is the equivalence relation.
In your case, ~ is the quotient map defined on S^2 . Show that all (2) elements
in each equivalence class are sent to the same value, so that the other map
passes to the quotient.
q
S<sup>2</sup> ---->S<sup>2</sup>/~
f / F
R<sup>4</sup>
Then the map you want is the only map that will make the above diagram commute
(double check everything, since I am kind of tired now.), a map
You can then use properties of the quotient topology, and the fact that a
continuous bijection between compact and Hausdorff is a homeomorphism,
to show the map is an embedding.
Does that Answer your Question.?
  • · Replies 17 ·
  • · Replies 30 ·
  • · Replies 17 ·
