Really hard infinite series test
The forum discussion focuses on the convergence of the series \(\sum_{n=1}^\infty (\sqrt[n]{2}-1)\). The integral test, ratio test, and root test were applied, all yielding inconclusive results. Participants suggested using the limit comparison test with \(\frac{1}{n}\) and \(\frac{\ln(2)}{n}\) to determine divergence. Ultimately, the discussion emphasizes the necessity of finding a suitable comparison series to establish the divergence of the original series.
  • Understanding of series convergence tests (integral test, ratio test, root test)
  • Familiarity with limit comparison test in calculus
  • Knowledge of LaTeX notation for mathematical expressions
  • Basic concepts of divergent series and comparison series
  • Study the limit comparison test in detail to apply it effectively
  • Explore examples of series that diverge and their comparison series
  • Learn about the integral test and its applications in series convergence
  • Practice using LaTeX for mathematical notation to improve clarity in discussions
Students studying calculus, particularly those focusing on series convergence, as well as educators seeking to understand common challenges faced by learners in this topic.
Doom of Doom
Test to see whether the following series converges
\sum_{n=1}^\infty \sqrt[n]{2}-1
All we've done so far is integral test, ratio test, and root tests.
As n approaches infinity, the term apporaches 0, so it may or may not converge.
A ratio test reveals r=1, so it is inconclusive
A root test also gives us 1, so it is inconclusive
I have no idea how i would take the integral of that.I do know that it diverges, but I have no idea how! I don't know why the prof would give such a hard homework problem.
use limit test and compare it to 1/n (use L'Hopital's rule)
Do you know the comparison test?
I don't understand you notation :(
But the gist of it is, we find a series that is term by term smaller than the series we wish to test. If the smaller series converges, the test is inconclusive but you can try another smaller series. But if the smaller series diverges, the larger one will as well. Is 1/n term by term smaller than your series?
It's this, Gib: \sum_{n=1}^\infty \sqrt[n]{2}-1. At least that's what the latex looked like it was trying to show!
1/n is bigger that this series term by term, so the comparison test does not work either!
Unless there is another series that is smaller than this series term-by-term that still diverges
How'd you get this? I think it's wrong.
StatusX,
when n=1, the terms are equal. When n=2:
1/2= 0.5
[2^(1/2)-1] =0.41421
note that .5>.414.
When n=3:
1/3=.33333
[2^(1/2)-1] =0.25992
The notation should be
\sum_{n=1}^\infty (\sqrt[n]{2}-1\ ) )
sorry for any confusion. I can't seem to get LaTeX to close the parenthesis on the outer end (outside the -1)
1/n may be larger than the series, but what about ln(2)/n?
Sorry, you're right. But the terms do tend to 1/n (from below), so for any c<1, c/n will eventually be dominated the series.
(Part of) The limit comparison test: if an > 0, bn > 0, and the limit of an/bn is greater than 0, then if \sum b_n diverges, then so does \sum a_n. Compare an = 21/n-1 to bn = n-1, since you know \sum n^{-1} diverges.
  • · Replies 16 ·
