Really quick explanation for gauge theory?
Gauge theory is a theoretical framework where unphysical variables correspond to the same physical situation, exemplified by gauge transformations that do not alter the physical state. A prominent example is Yang-Mills quantum field theory, which utilizes loops as physical variables. The discussion emphasizes the complexity of gauge theory, particularly SU symmetry breaking, and suggests several accessible resources for further reading, including papers and lecture notes that avoid excessive technical jargon.
  • Understanding of quantum mechanics (QM) fundamentals
  • Familiarity with quantum field theory (QFT)
  • Basic knowledge of symmetry principles in physics
  • Concept of gauge transformations and their implications
  • Read "Yang-Mills Quantum Field Theory" for an in-depth understanding of gauge theories
  • Explore the provided resources, such as the lecture notes from UCSD on quantum mechanics
  • Study the concept of SU symmetry breaking in particle physics
  • Investigate lattice gauge theory and its applications in computational physics
This discussion is beneficial for physics students, self-taught learners in quantum mechanics, and anyone interested in the foundational concepts of gauge theory and its applications in modern physics.
CookieSalesman
Could anyone give a really quick explanation for gauge theory to me?
Or a link, or a book is perfectly fine.
I just completely don't understand SU symmetry breaking and etc. etc.
I also have a question, is everyone who lurks around here a college professor on quantum physics or something? It seems that everyone knows a lot around here.
Sorry for double thread, I'll ask for this to be del'd after a few responses.
It's nigh impossible to give a "quick explanation" of something so elegant and deep. Here are some readings that don't use too much technical language:
http://scistud.umkc.edu/psa98/papers/weinstein.pdf
http://www.math.toronto.edu/~colliand/426_03/Papers03/C_Quigley.pdf
http://www.ippp.dur.ac.uk/~krauss/Lectures/IntoToParticlePhysics/2010/Lecture9.pdf
http://www.iop.vast.ac.vn/theor/conferences/vsop/18/files/QFT-4.pdf
No.
:OSo what are you guys?
Not high school students or undergrads, right?
I'm sure there are some, who knows. Suffice it to say, not everyone here is a university professor :smile:
A gauge theory is a theory in which one uses variables that are "unphysical", ie. different values of the variable correspond to the same physical situation. A gauge transformation is a "do nothing" transformation, since although it changes the values of the variables, the physical situation remains unchanged. A very simple example of a gauge variable is the electric potential: one can add any constant to the potential without changing the physical situation, since it is only the potential difference which is physical.
A famous gauge theory is Yang-Mills quantum field theory. There the physical variables are loops. In some cases, the physical variables are used (eg. lattice gauge theory), while in other cases unphysical gauge variables are used because they are calculationally convenient (eg. the path integral presentation found in most textbooks).
(I'm a biologist.)
Very true. Its has breathtaking elegance and beauty. It is very deep. But at the lay level, unfortunately, quite opaque.
But if you understand some of the technicalities of QM the following I posted before may be of value:
http://quantummechanics.ucsd.edu/ph130a/130_notes/node296.html
Thanks
Bill
There are many like that - but certainly not all.
I suspect I am in the minority, but not alone, in not being formally trained in physics
I have a degree in applied math but self taught myself QM and relativity.
The good news for those that aren't a 'college professor on quantum physics or something' is learning this stuff can be done. The bad news is it took me a while.
Thanks
Bill
  • · Replies 75 ·
10K
  • · Replies 33 ·
  • · Replies 36 ·
