Really silly Geometric Progression question
  • Thread starter Thread starter toneboy1
    Geometric
10 replies · 3K views
toneboy1
I should know this (it's been a few years) but can't seem to get the answer for: Ʃ (from i = 0 to n) 0.5-i the answer is apparently 2n+1-1 / 2 - 1
how do I go about getting this?
I tried Ʃn-1k=0ark = a* 1-rn / 1 - r
with no luck
= a* 1-rn+1 / 1 - r (which is wrong)Thanks very much!
toneboy1 said:
I should know this (it's been a few years) but can't seem to get the answer for: Ʃ (from i = 0 to n) 0.5-i the answer is apparently (2n+1-1) /( 2 - 1)
I tried Ʃn-1k=0ark = a* (1-rn) / (1 - rn)
with no luck
= a*(1-rn) / (1 - rn) (which is wrong)
Thanks very much!
First of all, you need to use parentheses to say what (I hope) you intend to say.
Start by letting [itex]\displaystyle \ S=\sum_{i=0}^{n}\left(\frac{1}{2}\right)^{-i}\ .[/itex]
Of course that means that [itex]\displaystyle \ S=\sum_{i=0}^{n}\left(2\right)^{i}\ .[/itex]
Then take 2S - S . What do you get?
Thanks for the reply SammyS, sorry about the lack of brackets, you were almost correct except I didn't have an n in the exponent of the denominator and I made up for the n-1 in the summation limit by adding n+1 to the n in the numerator (for the attempted solution)
Aaah, YES, that almost seems quite lateral in thought.
H'mm, not sure I'm following...'S'...?
Anyway, that equation I tried before now works if I'm not mistaken.
BUT this begs the question, what if rather than being a half (0.5) and being able to remove the numerator making the exponent positive, what if it was like pi ? what would we do then??
Thanks!
toneboy1 said:
Thanks for the reply SammyS, sorry about the lack of brackets, you were almost correct except I didn't have an n in the exponent of the denominator and I made up for the n-1 in the summation limit by adding n+1 to the n in the numerator.
I thought that 2S - S might trip you up.
To elaborate...
Write S as: [itex]\displaystyle \ S=1+\sum_{i=1}^{n}\left(2\right)^{i}\ .[/itex]
Write 2S as: [itex]\displaystyle \ 2S=\sum_{i=1}^{n}\left(2\right)^{i}\ \, +\ 2^{n+1}.[/itex]
Now, what is 2S - S ?
To elaborate...
would it just be 2S= 2n+1 - 1? Although I don't see how 2S was equal to the expression you said in the first place...?
Cheers
Mark44 said:
well I didn't see it.
Feel free to input anything else...like my question about what if it was 'pi'^-i.
I don't see how that would make any difference.
$$ \sum_{i = 1}^n \pi^{-1} = \sum_{i = 1}^n \frac{1}{\pi^i} = \sum_{i = 1}^n \left(\frac{1}{\pi}\right)^i$$
It's still a finite geometric series.
with no luck
Thanks very much!
What you WROTE is wrong because it means
[tex]a 1 - \frac{r^{n+1}}{1} - r,[/tex]
but if it was written properly as a(1-rn+1)/(1-r), it would be correct. What makes you think it is wrong?
RGV
Cheers
Write out a few terms:
[itex]\displaystyle \ 2S=2\sum_{i=0}^{n}\left(2\right)^{i}\[/itex]
[itex]\displaystyle =2\left(2^0+2^1+2^2+2^3+\dots+2^{n-1}+2^{n}\right)[/itex]
[itex]\displaystyle =2^1+2^2+2^3+2^4+\dots+2^{n}+2^{n+1}[/itex]
[itex]\displaystyle =\sum_{i=1}^{n}\left(2\right)^{i}\ \ +\ \ 2^{n+1}\[/itex]
How right you are, I was over complicating it in my head, thanks.
RGV
I was unnecessarily trying to minipulate it and ended up putting in the wrong value, like a circle through a square hole. Rather than just flipping it all.
Yeah, I'll not neglect the brackets again.
Legend, well explained, thanks!
