How can I sketch the reciprocal of a function with poles at x=-2 and x=2?
To sketch the reciprocal of a function with poles at x=-2 and x=2, recognize that the reciprocal will have roots at these points. The original function is symmetric about the y-axis, which means the reciprocal will also exhibit this symmetry. At x=0, the function's value is slightly above -1, indicating the reciprocal will be slightly below -1. As x approaches 2, the reciprocal graph will rise to y=0 and continue increasing toward positive infinity. This behavior suggests that the reciprocal graph resembles a quadratic function, particularly similar to the graph of -sec x, leading to a reciprocal resembling -cos x.
danago
Given the following graph:
http://img245.imageshack.us/img245/2395/scan0001ou4.gif
How can i sketch the reciprocal of that function? There are poles at x=-2 and x=2, so it means its reciprocal will have roots at -2 and 2 right? But that's not really enough information to compose a full sketch.
How should i go about doing this?
Thanks,
Dan.
It's enough for a rough sketch. You can see that the function is symmetric about the y-axis so its reciprocal will be. You can see that at x= 0, the function has value just a little larger than -1 so its reciprocal will have value just a little less than -1. The reciprocal graph will start at x= 0, y= a little less than -1, rise to x= 2, y= 0, then continue increasing as x goes to + infinity. Use symmetry to get the graph for negative x.
replace each y with 1/y for all x.
eg. where y is tending to infinity, it should tend to 0.
So it will be similar to a quadratic graph?
the middle portion is very similar to graph of -sec x, so its reciproca would be similar to -cos x
1/big = small
1/small = big
18K
