- 7,884
- 13,195
I am actually a Cubs fan=(Chicago is my hometown). Hopefully his number stays above .300. (I googled it=his lifetime batting average is currently .302).WWGD said:Sorry if this is OT: @Charles Link : Do you think Boo-Jols is likely to drop below .300?
If I am not completely off, likes have not been tracked for all those 7 to 8 years, so you get a bit of leeway there.Charles Link said:I see @fresh_42 is currently just 3 short of 5000. And he has done it in less than 3 years. After 7 or 8 years, with any luck, I just might make it to the first (3000) lounge.![]()
I've been on the Physics Forums for almost 3 years, and "likes" have been tracked for my entire time. At my present rate, it's going to be somewhere around a total of 6 years to get to 3000. The @fresh_42 5000+ inside of 3 years is quite remarkable.Orodruin said:If I am not completely off, likes have not been tracked for all those 7 to 8 years, so you get a bit of leeway there.
I remember "like" being introduced as "thanks". My earliest is September 27th 2013, so tracking starts from some time not too long before then for... errr... senior members.Charles Link said:I've been on the Physics Forums for almost 3 years, and "likes" have been tracked for my entire time
Also, I think ”thanks” was used much less frequently as it has other connotations. Likes were introduced with the new software in the fall of 2014, which significantly increased the rate of use (you would hardly ever see anyone but OP give a ”thanks”, ”like” seems much more open to others).Ibix said:I remember "like" being introduced as "thanks". My earliest is September 27th 2013, so tracking starts from some time not too long before then for... errr... senior members.
And yet, I remember WannabeNewton having infinity thanks.Orodruin said:Also, I think ”thanks” was used much less frequently as it has other connotations.
Infinity is not what it was ...Bandersnatch said:And yet, I remember WannabeNewton having infinity thanks.
Was it an 8 sideways?Orodruin said:Infinity is not what it was ...![]()
How about our data analysts find a regression equation between (number of) likes and thanks? And with infinity inputs too, that should help ML algorithms work even better!Orodruin said:Also, I think ”thanks” was used much less frequently as it has other connotations. Likes were introduced with the new software in the fall of 2014, which significantly increased the rate of use (you would hardly ever see anyone but OP give a ”thanks”, ”like” seems much more open to others).
Yes but only the count, any attributing data was lost.Orodruin said:I think thanks were converted into likes ... I may be misremembering.
@Drakkith is now just 22 messages away from being in first place in the most (trophy) points category. Meanwhile, I see @jedishrfu made an appearance the other day in the #20 spot of the most likes category, where he and @ZapperZ are very close, at around 3100.Orodruin said:Speaking of milestones, @Drakkith is less than 200 posts away from 20k messages and dethroning me from the most points lead.
I've seen it. Likes sometimes reduce. Greg must know that.mfb said:As far as I know the like counter doesn't change if a thread gets deleted.
Charles Link said:I see @Drakkith made 20,000 messages and now has the most trophy points. Congratulations !
You are not that far away from 5000 likes to take the lead again.Orodruin said:So ... the hunter becomes the hunted ...
Congratulations!![]()
Yes, the hunt is on!mfb said:You are not that far away from 5000 likes to take the lead again.
