Recursive vector squaring with patterns and sorting adjacent elements
  • Topic: Mathematica
  • Thread starter Thread starter Physics_rocks
    Functions Mathematica
1 reply · 3K views · last reply
Physics_rocks
Hi guys ,
I'm a little new with Mathematica and I'm trying to write down some functions.
the first one is writing a functions that square the elements in a vector , recursively ,
using patterns .
so , I tried this one :
x = Range[1, 10];
sq[0,list_]=list^2;
sq[sum_,list_] := Sum[sum*sq[sum, list[n - 1]], _list]
but it isn't working . what's the problem ? 2. The second function is writing a function that sorts a list of numbers , by checking each time two numbers that are adjacent .
if I write this : sort[list_] :=
how can I tell mathematica that I want to use an actual list of numbers ? can I say list ?
thank you
There seem to be multiple problems.
First of all, the assignment in the second line should probably be delayed (:= instead of =) because you want to substitute "list" for whatever value is passed. Also, list[n - 1] is a function call, you meant list[[n - 1]]? Anyway, what is n in that expression? Finally, what are you doing with the "Sum" expression? Sum[f[x], {x, a, b}] sums the values of f[x] for a <= x <= b.
Can you maybe explain more clearly what you want the function to do (e.g. if you input x = {1, 2, 3, 4, 5, 6, 7, 8, 9, 10}, do you want it to output {1, 4, 9, 16, 25, 36, 49, 64, 81, 100} ?)
2) How do you mean: "use an actual list of numbers"? You can call sort[x] (where x is defined as in your first example). In the expression after ":=", the expression "list" will contain whatever list you input (so if you call sort[x], then the definition is executed where list = x).
