Redox reactions oxidation number method
The discussion focuses on the method of determining oxidation numbers in redox reactions, specifically using iodine as the substance undergoing both oxidation and reduction. Participants clarify that when dealing with a single molecule like iodine, one must identify the changes in oxidation states, which are 7 and 1 in this case. The next step involves combining the half-reactions for oxidation and reduction, ultimately leading to a calculation of 7/4 after appropriate coefficient adjustments.
  • Understanding of redox reactions
  • Knowledge of oxidation states and their calculations
  • Familiarity with half-reaction method
  • Basic algebra for manipulating coefficients
  • Study the half-reaction method in detail
  • Learn about balancing redox reactions in acidic and basic solutions
  • Explore the concept of oxidation states in various chemical compounds
  • Practice problems involving iodine in redox reactions
Chemistry students, educators, and professionals involved in chemical analysis or reaction balancing will benefit from this discussion.
Coco12
1) Problem Statement
2) Relevant Equations3) Attempt at Solution
For question d, I realize in this case that the substance that is oxidized and reduced is the same molecule : iodine.
How do I proceed then as the next step would ask for you to find the change in oxidation numbers and multiplying by coefficients?
You would have 2 different changes number ( 7 and 1)?
Yes.
Borek said:
Yes.
Where do you go from there?
Same thing you do with other reactions - one half reaction is for reduction, other is for oxidation, just combine them.
So it would be 7/2 * 1/2 to give you 7/4 , then you multiply everything by 4?
I am not going to try to guess what you mean, if you want us to help it is up to you to explain what is what of what.
Thank you. I understand now.
