Refreshing stuff - transfer function
5 replies · 2K views
liquidFuzz
I'm trying to determine the transfer function to a simple circuit, see pdf. Is the simplest way to describe H(jω) by finding Y(jω) and U(jω) in H = Y/U. Further using the impedances for each component. If so, is each function Y(jω) and U(jω) determine by 'walking' through each impedance path giving something like this.
[itex]Y = \frac{1}{\frac{1}{Z_L} + \frac{1}{Z_C} }[/itex] and [itex]U = R +\frac{1}{\frac{1}{Z_L} + \frac{1}{Z_C} }[/itex]
[itex]Y(jω) = \frac{1}{\frac{1}{jωL} + \frac{1}{1/jωC} }[/itex] and [itex]U(jω) = R +\frac{1}{\frac{1}{jωL} + \frac{1}{1/jωC} }[/itex]
And next step simplify H(jω) to get the transfer function?
I'd really appreciate some help or pointers on this. Is this how it's done or..?
Hello,
Assuming your Y and U functions are voltages, then your Y function is incorrect for starters. You have equated your Y and U voltages to resistances, which is an incorrect approach (it doesn't make sense to have volts on the left side and ohms on the right side). You got steps 1 and 2 mixed up:
Step 1: Define a complex impedance Z, which is equal to the C and L impedance in parallel. Basically lump your C and L into an equivalent single component. You attempted to do this, but you mistakenly equated the impedance to your voltage function Y.
Step 2: Define your output voltage Y as a function of your input voltage U. The C and L in parallel, Z, acts as a voltage divider with R on U(jw): Z/(Z+R). this should be straight forward: http://hyperphysics.phy-astr.gsu.edu/hbase/electric/voldiv.html
Step 3: Solve the transfer function from the above equation by dividing out U from both sides.
liquidFuzz,
What is u(t), current or voltage? What is y(t), output admittance? The transfer function is determined by the components, not by the input voltage/current.
Ratch
Sorry! For violating Ohms law. :shy:
I didn't post any result in my last post, I get: [itex]H(jω) = \frac{ {jωL} }{{(jω)^2 CLR + R+jωL}}[/itex]
If I like to perform a Laplace transformation to get into the time domain, H(s) to h(t) to examining a pulse. How do I go from H(jω) to H(s)?
You are already there when you define s as s = jw. There is actually a real part too (s = jω + σ), but the sigma is ignored.
That transfer function result is the same that I got :)
