Rejection region of hypothesis testing
6 replies · 2K views
songoku
TL;DR
Let say I want to do one tail hypothesis testing using z - test with significance level of 10%. The null hypothesis is μ = 100 and alternative hypothesis is μ < 100. What will be the rejection region ?
From z-table, I get the critical value of z is -1.282
Will the rejection region be z < -1.282 or z ≤ -1.282? If I calculate the test statistics and it has value of -1.282, would I reject or accept null hypothesis?
Thanks
The odds of that are so small that you can really go either way. You should consider that the evidence of the alternative hypothesis is as weak as a 10% can get.
songoku said:
Summary:: Let say I want to do one tail hypothesis testing using z - test with significance level of 10%. The null hypothesis is μ = 100 and alternative hypothesis is μ < 100. What will be the rejection region ?
This one, since your null hypothesis is μ = 100. Really, though, the null hypothesis should be ##\mu \ge 100##, to accommodate samples with a mean larger than 100.
As already noted, it makes no difference practically to have z < -1.282 or ##z \le -1.282## to determine whether to reject the null hypothesis.
There are several levels at which to set the test: 10%, 5%, 2.5%, all the way down to ##5*\sigma = 3*10^{-7}## for discovering a new particle. The reason that the acceptance levels are set at those levels is to minimize the risk of a type I error (accepting the alternative hypothesis when it is false) or to convince a skeptical audience. You can do whatever you want with a result of ##z=-1.282##, but you should keep in mind the consequence of an error or how a skeptical audience would react.
It doesn’t matter. The difference in the probabilities between those two possibilities is 0.
Ok so it means that if the test statistics is the same as critical value, then rejecting or accepting null hypothesis should include other factor such as type I error or maybe some other logical reasoning or the experiment needs to be repeated to have more certain data
Thank you very much FactChecker, Mark44, Dale
While this is absolute correct mathematically, practically there is some cutoff - if you are using Excel floating point the 90% cutoff is
1.2815515655446​
So at that precision it practically does not matter, however if you are just going to 3 decimal places, 1.282 is slighly more than the 90% percentile while 1.281 is closer
