Related Rates, elliptical motion
3 replies · 6K views · last reply
Tclack
A satellite is in an orbit around earth. The distance from the center of the Earth is described by
r= 4995/(1+.12cos@) R earth= 3960 mi
find the rate at which the altitude is changing at the instant where @=120 degrees. d@/dt= 2.7 degrees/min
2. Notes
altitude equals r - (R earth)
"@" describes the angle the satellite forms with the Perigee of Earth (the closest point)
a = r - (R earth) = 4995/(1+cos@) - 3960
da/dt= [-4995(-sin@)d@/dt]/(1+cos@)^2
by plugging in the values I get: ~ 46,700 mi/min
The answer from back of book is 27.7 mi/min
I do find it a mystery that the R Earth is not used, that may be a key to solving it. Help!
Hi Tclack! :smile:
(have a theta: θ :wink:)
erm :redface: …
what happened to .12? :cry:​
r=\frac{4995}{1+\frac{3}{25}cos{\theta}}
\frac{dr}{dt}=\frac{374625sin{\theta}}{(3cos{\theta}+25)^{2}}\cdot\frac{d{\theta}}{dt}
I am using radians, so be careful with the 2.7. That is \frac{3\pi}{200} rad.
So, we get:
\frac{dr}{dt}=\frac{374625sin{\frac{2\pi}{3}}}{(3cos{\frac{2\pi}{3}}+25)^{2}}\cdot\frac{3\pi}{200}=\frac{44955\sqrt{3}{\pi}}{8836}\approx 27.6843 \;\ \frac{mi}{min}
The reason the R is not used is because the given equation has it incorporated and already gives the distance from the CENTER of the Earth.
Hi Tclack! :smile:
Tclack said:
[tex]r=\frac{4995}{1+\frac{3}{25}cos{\theta}}[/tex]
[tex]\frac{dr}{dt}=\frac{374625sin{\theta}}{(3cos{\theta}+25)^{2}}\cdot\frac{d{\theta}}{dt}[/tex]
So, we get:
[tex]\frac{dr}{dt}=\frac{374625sin{\frac{2\pi}{3}}}{(3cos{\frac{2\pi}{3}}+25)^{2}}\cdot\frac{3\pi}{200}[/tex]
[tex]=\frac{44955\sqrt{3}{\pi}}{8836}[/tex]\approx 27.6843 \;\ \frac{mi}{min}
(you needed to type [noparse][tex]before and[/tex] after [/noparse] :wink: …)
Sorry, but this is too difficult to check unless you show more of the steps. :redface:
(and you have at least one minus sign wrong)
