Relating acceleration to distance and time
golya
Given distance = 402 metres and time = 5.5 seconds, I need to find acceleration.
vˉ= vf/2 = (at)/2
I’m an absolute beginner and I need someone to show me where I’m wrong.
Knowing the formula of acceleration ∆v (change in velocity) / ∆t (change in time) where ∆v = ∆x (distance) / ∆t, a common way of relating acceleration to distance is to say a (acceleration) = (distance/time)/time = distance/time^2.
Thus I proceeded by calculating a = 402/5.5^2 = 402/30.25 = 13,28 m/s^2. In the same manner I thought I could calculate velocity = 402/5.5 = 73.09 m/s.
However, my textbook reaches a different answer where I don’t understand the thought process.
My textbook proceeds with the formula
s (displacement) = vˉ (average speed) x t (time)
continuing with the formula
vf (final speed) = a x t
deriving
vˉ= vf/2 = (at)/2
Plugging into the above formula s= vˉt, we reach
s = [(at)/2]t = at^2/2
Only now it proceeds to deriving acceleration from displacement and time:
a = 2s/t^2 = 2x402 m / 5.5s^2 = 27 m/s^2
In short, my attempt was using ∆v while their procedure is using vˉ reaching exactly twice my answer because vˉ= vf/2 where vf = ∆v assuming constant acceleration.
But why do they use average velocity instead of change in velocity if a = distance/time^2?
What am I missing?
golya said:
Homework Statement: Given distance = 402 metres and time = 5.5 seconds, I need to find acceleration.
Relevant Equations: vˉ= vf/2 = (at)/2
This is not right. Average velocity is displacement/time. Velocity is the derivative of displacement with respect to time:$$v_{avg} = \frac{\Delta x}{\Delta t}$$$$v = \frac{dx}{dt}$$
He is right because the acceleration is constant and the initial speed is 0
I think I understand what happened.
My first mistake: distance/time^2 is NOT actually a formula for acceleration but merely an illustration of why acceleration is measured in terms of m/s^2. Therefore the phrase refers merely to units of measurement and not to a formula.
My second mistake: the formula ∆x/∆t (distance/time) does not yield ∆v (change in speed) but vˉ (average speed). This second mistake was the result of the first one.
Therefore the textbook procedure makes sense.
You're wrong as well. Assuming constant acceleration from rest:$$\Delta x = \frac 1 2 a t^2$$$$a = \frac{2\Delta x}{t^2}$$
Thank you!
  • · Replies 17 ·
