Relative error of a geiger counter?
The discussion focuses on calculating the average counting rate, standard deviation, and relative error of a Geiger counter measuring 750 counts over 5 minutes. The average counting rate is determined to be 150 counts per minute, with a corrected standard deviation of 5.48 counts per minute, leading to a relative error of 3.65%. To achieve a relative error of 1%, a total of 10,000 counts is required, which would take approximately 66.7 minutes at the given counting rate.
  • Understanding of statistical concepts such as standard deviation and relative error
  • Familiarity with the principles of nuclear decay and Gaussian distribution
  • Knowledge of error propagation techniques in measurements
  • Basic proficiency in using Geiger counters for radiation measurement
  • Learn about error propagation in experimental physics
  • Study the principles of nuclear decay and its statistical properties
  • Explore advanced statistical methods for analyzing measurement uncertainties
  • Investigate the calibration and optimization of Geiger counters for precise measurements
Students in physics or engineering, researchers working with radiation detection, and professionals involved in experimental measurements and data analysis.
carnivalcougar
A geiger counter measures 750 counts in 5 min
a) determine the average counting rate and the standard deviation of the counting rate.
b) find the relative error
c) How long would you want to count to get a relative error of 1%?
standard deviation = \sqrt{}navg
relative error = δx/x
The average counting rate is 750/5 which is 150 counts / min and the standard deviation is the square root of that which is 12.247. The relative error is 12.247/150 which is .0816 which is 8.16%
I'm not sure how to determine how long you would want to count to get a relative error of 1%
There is an error in the attempt of the first part of the question i.e. standard deviation of the count rate.
The count rate = total counts/time = N/t
A change , error, or uncertainty in the count rate is related to those of the total counts and the time by taking the differential of the count rate equation.
dR = dN/t - N⋅dt/t2
where the terms on the right hand side are the contribution of the uncertainties of both the total number of counts and the time to that of the count rate.
Using the propagation of error to determine the average uncertainly in the count rate we can write
σR2 = √[(dN/t)2 + (N⋅dt/t2)2]
where dN = √N because nuclear decay follows a Gaussian distribution..For all practical purposes dt =0 so
σR =√N/t that is √750/5 = 5.48 cnts/min
with a relative error of σR/R = 5.48/150 =.0365
Now to address the OP's question on how to determine the count time to achieve a certain precision for the count rate.
The precision sought is 1% thus the relative error is .01 so
σR/R = .01 =√N/t / N/t =1 /√N Thus N = 10000
So one must count until the total accumulated counts is equal 10000, Notice that this is true for any count rate! If you need to know the time say for scheduling purposes then using the estimate of the count rate as 150 cnts/min we expect it to take about 66.7 minutes to reach 10000 counts.
Considering the uncertainly in the count rate of 3.65% we can estimate that the uncertainly in the time to accumulate 10000 counts will be about 66.7×.0365 = 2.4 minutes.
Or more exactly οt = (N/R)×√[ (σR/R)2 + 1/N]
Just to note that the original method, taking the square root of the rate, makes no sense dimensionally. It produces a s.d. of dimension ##T^{-\frac 12}##. This might have been a clue.
haruspex said:
Just to note that the original method, taking the square root of the rate, makes no sense dimensionally. It produces a s.d. of dimension T−12T−12T^{-\frac 12}. This might have been a clue.
Good point thanks.
