jfy4
- 645
- 3
Hi,
I was looking at the relativistic equation for energy E^2=p^2+m_{0}^2 and was wondering about a methodology I took with it. Making the substitution E^2=\gamma^2 m_{0}^2 then
p^2=m_{0}^2(\gamma^2-1)
Considering only the \gamma-1 factor, this can be expanded
\gamma-1=\frac{v^2}{2}+\frac{3v^4}{8}+\frac{5v^6}{16}+...
I then made the identification with E=\hat{E},
\hat{E}=i\hbar\frac{\partial}{\partial t}
which yields the following from before
p^2=m_{0}^2\left(\left(\frac{i\hbar}{m_0}\frac{ \partial }{\partial t}\right)^2-1\right)
which led me to again identify
\gamma-1=\frac{i\hbar}{m_0}\frac{\partial}{\partial t}-1=\frac{v^2}{2}+\frac{3v^4}{8}+\frac{5v^6}{16}+...
If I make the appropriate substitution for v=\hat{v}
\hat{v}=\frac{i\hbar}{m_0}\nabla
and write the sum on the right as
<br /> \sum_{n=1}^{\infty}\frac{\left(1+(-1)^n\right) \left(\frac{1}{2} (-1+n)\right)!}{2 \sqrt{\pi } \frac{n}{2}!}\hat{v}^n<br />
Then I end up with
i\hbar\frac{\partial}{\partial t}\psi=m_0\psi+\sum_{n=1}^{\infty}\frac{\left(1+(-1)^n\right) \left(\frac{1}{2} (-1+n)\right)!}{2 \sqrt{\pi } \frac{n}{2}!}m_{0}^{1-n}\left(i\hbar\nabla\right)^n\psi<br />
Now for n=1, this equals
<br /> i\hbar\frac{\partial\psi}{\partial t}=m_0\psi<br />
which seems manifestly true (EDIT: by which I mean, there are no kinetic energy terms on the right), and for n=2
<br /> i\hbar\frac{\partial\psi}{\partial t}=m_0\psi-\frac{\hbar^2}{2m_0}\nabla^2\psi<br />
which seems Schrödinger-esque. So I was wondering... for n=4 (which is the next time a term is added on)
<br /> i\hbar\frac{\partial\psi}{\partial t}=m_0\psi-\frac{\hbar^2}{2m_0}\nabla^2\psi+\frac{3\hbar^4}{8m_{0}^3}\nabla^4\psi<br />
is the last term on the right a relativistic correction to the Schrödinger-esque equation above it?
Thanks,
Then I end up with
Thanks,
