wil3
- 177
- 1
Hello. I am trying to better understand relativistic inelastic collisions for objects with mass and the setup for them.
Let's say that I have two objects with different masses, one of which collides with the other, which is stationary.
Without even specifying a reference frame, can I solve for the final velocity of the composite using just momentum conservation? Ie, as long as I apply the Lorentz correction to momentum, won't it be conserved (although the initial and final momenta will have different velocity-dependent Lorentz factors)
In this case, I would assume that the rest mass of the composite is just the sum of the initial rest masses, since no photons escaped. Is this a valid assumption to make? This troubles me, because it does not seem to require specifying a reference frame.
Thanks very much.
Thanks very much.
