Relativistic length, 2 viewpoints
  • Level: Graduate
  • Thread starter Thread starter pacu
    Length Relativistic
pacu
Problem statement:
Two identical cyclists ride past each other with constant velocities Va and Vb, which are close to the speed of light. Can it be that cyclist A perceives cyclist B as shorter or longer that cyclist B perceives cyclist A ? Or simply La is NOT equal to Lb ? (La-length of cyclist A as seen by cyclist B, Lb -length of cyclist B as seen by cyclist A).
Relevant formulas:
Relative speed V = Va+Vb/(1+(Va*Vb/c^2))
Relative length l = lo * square root from 1-(V/c)^2
Conclusion:
The V from the second equation is equal for both cyclists, since addition and multiplication are alternate. lo is also equal. So there is no difference in the way cyclists A and B see each other.
Is this conclusion right?
its correct if the cyclists are the same length to begin with.
dont forget that there is also a loss of simultaneity. once you factor that in it stops seeming so impossible.
