Relativistic Momentum of a particle of mass
The discussion focuses on calculating the relativistic momentum and mass of a second fragment after a particle of mass m(naught) explodes into two fragments. The initial particle moves at 0.6c, and one fragment has a mass of 0.66m(naught) moving at 0.8c. Participants emphasize the importance of using the invariant mass instead of the outdated concept of relativistic mass and suggest applying conservation of momentum and energy principles to solve for the unknowns. The correct approach involves setting the total momentum and energy before and after the explosion equal to each other.
  • Understanding of relativistic momentum equations
  • Knowledge of conservation laws in physics
  • Familiarity with high-velocity particle energy equations
  • Basic grasp of special relativity concepts
  • Study the conservation of momentum in relativistic collisions
  • Learn the energy equation for high-velocity particles
  • Explore the implications of invariant mass in relativistic physics
  • Practice problems involving particle decay and explosion scenarios
Students and educators in physics, particularly those focusing on special relativity and particle dynamics, as well as anyone interested in advanced mechanics and energy conservation principles.
Sierevello
A particle of mass m(naught) moves through the lab at .6c. Suddenly it explodes into two fragments. Fragment 1 has mass .66m(naught) and moves at .8c in the same direction as the original particle had been moving. Determine the velocity (magnitude and direction) and mass of fragment 2?
m = m(naught) / sqrt (1-(v^2/c^2)
p = m(naught) v(naught) / sqrt (1-(v^2/c^2)
I have worked this problem for the last 3 hours. I am not sure how to find the mass of the 2nd particle and also everytime I work the problem I get a nonsense answer. I understand that momentum is conserved and initial energy = final energy. I was trying to use
p total = p piece 1 + p piece 2 where p is the relativistic momentum.
The m(naught) is throwing me off also.
Thansks for any help.
What you denote as "m" is something called relativistic mass, which is becoming an outdated concept. I would suggest dealing only with the invariant mass, which you currently call "m(naught)" and many other people just call "m". So your formula for momentum becomes
[tex]p = \frac{mv}{\sqrt{1 - \frac{v^2}{c^2}}}[/tex]
and there is no need for anything to be called "m(naught)"
Anyway, you have a formula for momentum of a high-velocity particle. What's the formula for energy of a high-velocity particle? Once you have that, use the fact that total momentum is conserved in a collision, and total energy is also conserved. So compute the total momentum before and after the collision and set them equal to each other; also, compute the total energy before and after the collision and set them equal to each other.
If you get stuck after that, post your work here so we can point out any mistakes.
  • · Replies 16 ·
