Relativity Explained Via Movement, Not Time
104 replies · 16K views
my_wan said:
The scaling is required simply so that our choice of event sets to count time is independent of the particular set of events used to do the counting.
That doesn't make any sense at all if time IS the count. How can time be the count of events and yet be independent of the events counted?
It is not independent of the count, which is the point. But if you have an event set, and many different ways of combining those set and subsets, then to get any meaningful count they all must be given a consistent scale, even though nature is scale independent in general. The reason they can be scaled together would be because they are are mere regrouping of the same sets.
You just said that you needed to scale it so that it was independent.
And exactly what is it that must be consistent about the scale? In other words, you have two valid sets of events to count and you scale one by a factor of two in order to achieve consistency, what is it about the events that required a factor of two scaling to achieve consistency, and how can you know that you need a factor of two and not three?
I said independent of our "choice" of event sets, not independent of the events themselves.
Two parts:
1: "events that required a factor of two"
If you have a single finite superset of events and you have a measuring device that measures ticks for ever pair of events, then that MUST relativistically scale as 2 times every event. How much linearity there is between the individual events is immaterial, like claiming you can stop time for some specified period of time. Even if it we overlook the silliness and presumed it did occur it has NO empirical meaning.
2: "how can you know that you need a factor of two and not three"
Because the clock that counted one event for every two events would not be linear by any measure other than a 2 to 1 ratio. This ratio is what defines what we can measure, not the naked quantity in itself. That would require absolutes like in Newtonian physics.
Unfortunately, I will not be able to continue the conversation tonight. I thought it would take fewer iterations than it did.
The point is that this definition of "time is counting events" is not sufficient. There are some events which counting them doesn't measure time because the events are separated by space, not time. There are other events which counting them does not measure time because they are at random intervals. For still other sets of events you have a good feeling that they are measuring time, but you have to scale your counts in order to say that they are all measuring time. So for all of these reasons there is more to measuring time than simply counting events.
All of these objections can be addressed, but to do so requires that you identify something about the various counts beyond the mere counting itself. The very fact that you can use counts of a variety of sets of events (properly scaled) to measure time indicates that there is something else besides simply the counting.
Unless you already have some concept of time already then there is no way to distinguish between spacelike sets of events and timelike sets of events. Unless you already have some concept of time then there is no way to determine if the scaling is correct.
What the counts and their scaling do is to define a unit of time, not to define time.
I don't know how this post 'relativity explained by movement, not time' got so far off track.
You got movement, you got:
(amount of) space/time.
Time will always be around in the physics-conversation.
I am accustomed to certain people, including physicist, who seem to grasp it straight away as though it was too obvious to mention, and others who find it very difficult.
Is actually is sufficient. In fact from a purely empirical perspective some form of event counting is ALL we have. The derivation of the relativity of simultaneity is possible exactly because we can count event rates of external observers as measured by our own evet rate counters and compare the compare the incongruities. If time existed independently of these event counts why would the difference in events counts result in an actual difference in time rates per Lorentz? The one issue that imposes any other constraints that might qualify as indicating "count" is not "sufficient" is the extra constraint imposed by causality itself, i.e., the same event cannot occur both before and after a reference event at a point in space.
In those situations where the event count does not match your own local event count then you are measuring is not your own event count but somebody else's. Which we know to be real differences in real time else you could not come back younger than your own kids. The separation by space rather than time is moot by the inverse relation between space and time such that empirically they are not separate quantities.
The randomness of an interval does not invalidate the linearity of those intervals on average. The rate of molecular collisions also have highly random intervals. Yet in order for Gibbs ensembles to have any empirical meaning they must average to a constant if equilibrium is maintained. This is the physical basis of emergent gravity theories based on relations defined by Brustein and Hadad and others where equilibrium is not maintained.
http://arxiv.org/abs/0903.0823
Randomness of intervals do not have any relevance to the constancy of average intervals one way or the other, but it would have relevance to the certainty with which we could, even in principle, determine a precise location in space or time relative to any observer.
If I locally measure an inertial string and say it has a lengths of X and you measure it locally and say it has has a length of Y, why must we scale X and Y so to be equivalent? Because we are measuring the "same" string. Same thing if we are both measuring the "same" general set of local events. How do you treat background independence by any other means?
For all those same reasons, plus background independence causality, "counting events" is completely "sufficient".
Yes, they can be enumerated as such:
1: Causality - The same event A cannot occur 'both' before and after event B at any given point in space-time.
2: Background Independence - The rate of a non-observable is empirically moot irrespective of what role it plays in the theoretical framework.
3: Relational, i.e., Relativity - The only value we can measure are not naked values, rather ratios which we assign a specific value to as though our local base event sets defined absolutes.
Yes causality constraints. Yet the fact that locally the event sets being measured in for all practical purposes the same set of events requires that both measures scale together. Hence the scaling requirement is a physical requirement of consistency. Not some magical entity that exist in a matter free background.
Absolutely true and well established physics, which is precisely why we get the so called clock paradox in SR. We can only make such distinction locally, due to the fact that we are essentially measuring the same space-like and time-like sets. Once you consider other points in space-time what you say here about the event count ideology is exactly true and well defined by Relativity. You can only pretend that space and time-like intervals are unique in pair of reference frames by assuming that one of those frames has a special status in its capacity to define those distinctions.
If a ruler and a string were all that existed in the Universe how do you know the scaling of the ruler is correct. With background independence (also called coordinate independence) 'correctness' of a scale makes no difference whatsoever. We know that the ruler can linearly scale to itself and we know the ratio between the ruler and the string, what else empirically matters? How big the ruler and the string both are is a physically absurd empirically moot question.
So if a Hilbert space is a mathematical tool with no 'real' physical significance, what makes the mathematics of defining time so special that somehow it is not only more real but 'real' independently of the intervals we measure? (That is not saying it is dependent on our choice of interval sets.)
@DaleSpam: @my wan: Is the difference between your points of view that physics is always the study of change dy/dx, but if there is only one "dimension" DaleSpam would call that "space" and my wan would call it "time"?
No, the count of a set of spacelike separated events is not measuring anyone's time.
You are contradicting yourself saying that "counting events" is completely sufficient and then adding constraints. The "time is counting events" definition is clearly insufficient as you have de facto conceded. You must add such enumerated constraints or clarifications as above.
The causality constraints are particularly problematic for a definition of time. Causality requires a notion of time, so putting a causality constraint into your definition of time makes the definition circular. In particular, without a definition of time how do you determine "before" and "after"?
Btw, I am not opposed to a background independent relational definition of time. I just think that "time is counting events" is way oversimplified. Something this important needs quite a bit more effort and care than that. Many things which qualify as counting events do not qualify as measuring time.
I have not asserted a point of view here, I am only pointing out that "time is counting events" does not work. I believe that I understand my_wan's motivation, I think he wants to avoid the Newtonian idea of time as some undetectable thing which flows and instead focus only on the physical observables. I agree with that goal; I just think that his approach is not right.
That's sounds interesting. Is the undetectable point of view to define time as the proper time along a time-like curve even though no physical clock exists on the curve? Is the detectable point of view to define time via a clock such as the number of vibrations of an atom/light?
The undetectable view would be something along the lines of Newton's definition of "absolute" time or Lorentz's definition as "real" time in the aether frame. I wouldn't be bothered with something that is detectable in principle (like the proper time along a curve) even if you don't detect it, but I don't know my_wan's opinion on something like that.
Why is Newtonian time undetectable in a way that the proper time along a time-like curve isn't?
Because Newton defined it that way:
"Absolute, true and mathematical time, of itself, and from its own nature flows equably without regard to anything external, and by another name is called duration: relative, apparent and common time, is some sensible and external (whether accurate or unequable) measure of duration by the means of motion, which is commonly used instead of true time"
So here he expressly differentiates between "apparent" time and "true" time based on the idea that "true" time cannot be detected even in principle.
Oh, I was just thinking that Newtonian time is the t when the equations are expressed in an inertial frame. Would that definition be detectable (in principle)?
I think that would be detectable in principle. I kind of like that definition. It wouldn't be hard to generalize.
This is where Aristotle got all mucked up with the mystical 'Now'. Now's, according to him, are between the before and after. But before and after are just comparisons of how things are, or how we see them. The car was in the driveway before it was in the street. The clock pointed at 1:00 before it pointed at 1:01. Or backwards. If you stick a Now between the before and after, you have two sets of befores and afters.
Here's what's in my craw though, is that starting with Time and trying to define it doesn't work. The reason Time's a count isn't because that's the great definition of Time. It's because we looked at things changing and then called that Time. It's the changes that are at the center. We're just looking at changes and putting some counter to them so that we can compare other changes to that counter.
It's a paradigm shift. You can even forget little t. You take two things changing and compare them. That's what velocity (or speed, rate, frequency, etc.) is - two counts of two things changing and then comparing the two. Instead of calling the count of the clock little t, you just call it the count of the clock.
And of course, all counters work differently under different conditions. Even the second's defined as a count at a specified temperature.
I've read various versions of this definition of Newtonian time ("time is what makes the equations of motion true") in Stephani's and Misner, Thorne and Wheeler's GR texts. That makes it like the proper time and coordinate times of Lorentz inertial frames which exist even in special relativistic field theories which happen not to have any periodic solutions (although in real life theories, we luckily seem to have solutions that are periodic for all practical purposes).
Then you should define time in terms of changes, not counts.
I am not going to re-hash the conversation that I just went through with my_wan, go back and see all of the reasons why "time is a count of events" is insufficient. You need to add some constraints, and so far those constraints make the definition circular.
No that would not work for my opinion and almost certainly would not work for DaleSpam even before reading his response. Neither DaleSpam is making any claims that empirically differ from the standard formulation. I am only arguing that as defined such an event based interpretation works.
I stated that constraint up fron even before you made the first response to me and in my very first response to you. So no that is not a contradiction.
Consider what it we count in a standard derivation of the Lorentz transform. Take the light mirror where light is bouncing back and forth between two mirrors. We are counting the bounce events at each mirror. If we merely watch the clock we are counting ticks of the clock, etc. In fact we cannot measure "anything" without checking off events that are registered. Whether of not there is a smallest or most fundamental event is immaterial to the argument.
I agree simply saying "time is counting events" is a bit oversimplified. Einstein simply said: "Time is what we measure", and I am saying what we measure are events. The statement really does not go much further than that. It is not fundamentally different. Yet since time effects all else we measure a lot more is involved than just the statement itself. Events can be defined in terms of intervals and that is what SR defines. When we "count" such events we plot them on a graph and curve fit them, taking the limit. But The limiting factors work whether the events involve actual limiting points or not.
Islam Hassan said:
Why then do physicists persist in using the notion of "time" in explaining relativity? It would be so much easier, more intuitive and correct to talk of (relative) movement and not time.
Can you show how relativity can be defined using relative motion alone in the absence of using space and time?
GrayGhost
Excellent.
Yes, I think that is a better approach since the interval is equal to the scaling you were referring to earlier, it contains the causal structure, and it can be used to exclude the timelike sets of events I mentioned.
DaleSpam said:
Excellent.
There are so many ways to look at relativistic effects that are not wrong it is ridiculous. It is only when you try and say what the "real" (absolute) metric of the interval is that it goes over the edge. That makes it a generally a bad idea to think in terms of specific metrics, but the event count works because it does not specify any metric for such events except relativistically.
Whether or not there is a fundamental Planck cutoff or such intervals are maintained in the limit as Einstein imagined is an open question. Since you can just as easily take the limit on events as you can an interval it makes no empirical difference either way. If there is a Planck cutoff it just means your fit become choppy and irregular at very small intervals, macroscopically normalized by a Poisson distribution.
danR said:
The thing is the thesis of this post: Relativity explained via Movement, not "Time". In fact, we could re-write the title:
'Relativity Explained by L/t, not "t".'
Well enough. I don't think that's too far from what Einstein said, the L/t in question being c, which is a constant in all observers' frames of reference. Sorta QED, no?
In my humble opinion that is a step in the right direction. If I recall correctly, even Einstein himself was initially inclined towards "invariantentheorie" instead of 'relativity' theory. I can't quite recall who prevailed upon him to name it relativity instead.
The benefit to my mind is that by concentrating on the measure of an absolute, invariant movement reference which is c, you avoid saying things like 'time will do this' or 'time will do that', avoid treating time in the agentive form. It is a linguistic point but important to the layman like me who is trying to understand relativity. It is much easier to conceive and understand of material objects which move than immaterial notions that dilate or flow...
IH
DaleSpam said:
Excellent.
Agreed, time as a notion covers both counting and sequencing, the premise being that the sequence is ever-increasing.
GrayGhost
In terms of definition, one needs an absolute movement reference which is c, a set of events and the notion of simultaneity. The movements linked to relative events can be physically measured in space as can c. The instrument which we use to link these is simultaneity which is elaborated in our minds based on our physical perceptions and measurements. The collective set of simultaneous events provides the structure of our notion of time. Time remains a notion and not a physically measured phenomenon.
To redefine relativity in terms of motion alone, I would imagine one needs to benchmark all movement to the simultaneous movement of a photon. To my mind, simultaneity does not imply the physical measure of time, just the physical measurement of co-perceived events. The co-perception is a product of our willed sequencing and measurement, not in my opinion of 'physical' time.
IH
I don't understand your point here. All the spacetime metrics that I know of are relativistic. I have no idea what you mean by '"real" (absolute) metric' and why you think that would make it "a generally a bad idea to think in terms of specific metrics" (e.g. Schwarzschild metric).
Islam Hassan,
OK. So basically, model relativity w/o the use of time using only the relation of events based upon our sense of simultaneity and using an invariant speed photon as a common reference. IOWs, do what Einstein did, w/o using time, but rather using something else instead. In your estimation, that "something else" should be physical and not a man made notion. For otherwise, you'd simply be replacing what you believe to be one man made notion for another ... and then the big question is, would anything be gained or lost?
Can you give one simple example of how the extent of relative motion would be quantified w/o using time? Have you ever tried this?
GrayGhost
The same stuff when you try to ask questions like which clock is "really" go slower. Gr effects makes invariants verses constants issue even more relevant, since it distorts SR in ways that makes the constants more like a choice. Take the apparent mass of an object as its depth in a gravitational field varies. Einstein chose perfectly sensibly to define it as 'apparent' mass. But if you get exactly the same effect if the 'apparent' gravitational constant was what varied, or even the 'apparent' speed of light. In Einstein' words:
"Relativity: The Special and General Theory" said:
In the second place our result shows that, according to the general theory of relativity, the law of the constancy of the velocity of light in vacuo, which constitutes one of two fundamental assumptions in the special theory of relativity and to which we have frequently referred, cannot claim any unlimited validity.
In context this does not invalidate the constancy of the speed of light. This general feature extends to all invariants, not constants. Hence the QG community has their controversy over how much this applies to Planck's constants. This is also the basic theme behind "doubly special relativity". Note why GR gets in trouble with Planck's 'constant' when in terms of Planck length and time:
[tex]c = \ell_p/t_p[/tex]
Planck mass:
[tex]m_P=\sqrt{\frac{\hbar c}{G}}[/tex]
So you can take any first order quantity and express it in terms of pure constants, called the indefinables of physics (space, time, and mass/energy), where all must 'locally' be invariant or more generally some multiple thereof. Yet globally they vary, in the same way light speed does in GR, where the manner in which they vary is both frame dependent and definition dependent, like the apparent mass verses apparent value of G. That is where the so called varying speed of light (VSL) theories get their 'theoretical' legitimacy from. Not from any claim that the speed of light 'actually' changed, as Einstein articulated following the quote I give above.
