Mentor
- 37,333
- 16,481
Do you have a good definition of the word "real"? I certainly don't. Without one you will always run into trouble whenever you ask any questions about the reality of anything. That is hardly any kind of argument against that thing.my_wan said:The same stuff when you try to ask questions like which clock is "really" go slower.
None of this seems to indicate why using the metric is a bad idea.my_wan said:Gr effects makes invariants verses constants issue even more relevant, since it distorts SR in ways that makes the constants more like a choice. Take the apparent mass of an object as its depth in a gravitational field varies. Einstein chose perfectly sensibly to define it as 'apparent' mass. But if you get exactly the same effect if the 'apparent' gravitational constant was what varied, or even the 'apparent' speed of light. In Einstein' words:
In context this does not invalidate the constancy of the speed of light. This general feature extends to all invariants, not constants. Hence the QG community has their controversy over how much this applies to Planck's constants. This is also the basic theme behind "doubly special relativity". Note why GR gets in trouble with Planck's 'constant' when in terms of Planck length and time:
[tex]c = \ell_p/t_p[/tex]
Planck mass:
[tex]m_P=\sqrt{\frac{\hbar c}{G}}[/tex]
So you can take any first order quantity and express it in terms of pure constants, called the indefinables of physics (space, time, and mass/energy), where all must 'locally' be invariant or more generally some multiple thereof. Yet globally they vary, in the same way light speed does in GR, where the manner in which they vary is both frame dependent and definition dependent, like the apparent mass verses apparent value of G. That is where the so called varying speed of light (VSL) theories get their 'theoretical' legitimacy from. Not from any claim that the speed of light 'actually' changed, as Einstein articulated following the quote I give above.
As you and I have already agreed, you cannot simply count events to get time, you must add some additinal constraints. In particular you mentioned causality and scaling, both of which are provided by the metric. So I don't see any difference between defining time in terms of counting events with scaling and causality constraints and defining time in terms of the metric.
