What is the Remainder When f(x) is Divided by (x+1)?
The discussion centers on finding the remainder when the polynomial function f(x) is divided by (x+1). The key takeaway is that since f(x) is divisible by (x-1), the remainder R(x) can be expressed as R(-1) when evaluated at x = -1. The participants suggest using specific polynomial examples, such as f(x) = (x-1), to illustrate the division process. Ultimately, the remainder when f(x) is divided by (x-1)(x+1) is determined to be f(-1)(1-x)/2.
  • Understanding polynomial division and the Remainder Theorem
  • Familiarity with polynomial functions and their properties
  • Knowledge of evaluating polynomials at specific points
  • Basic algebraic manipulation skills
  • Explore polynomial long division techniques
  • Learn about the Remainder Theorem in detail
  • Investigate examples of polynomial functions and their remainders
  • Study the implications of polynomial divisibility on function behavior
Students and educators in algebra, mathematicians focusing on polynomial functions, and anyone interested in understanding polynomial division and remainders.
songoku
Given that ##f(x)## is divisible by ##(x-1)##, then the remainder when ##f(x)## is divided by ##(x-1)(x+1)## is
a. ##- \frac{f(-1)}{2} (1+x)##
b. ##- \frac{f(-1)}{2} (1-x)##
c. ##\frac{f(-1)}{2} (1+x)##
d. ##\frac{f(-1)}{2} (1-x)##
e. ##\frac{f(-1)}{2} (x-1)##
polynomial
##f(x)## is divisible by ##(x-1) \rightarrow f(1) = 0## ##f(x) = Q(x).(x-1)(x+1) + R(x)## where ##Q(x)## is the quotient and ##R(x)## is the remainderSeeing all the options have ##f(-1)##, I tried to find ##f(-1)##:
##f(-1) = R(-1)##
I do not know how to continue
Thanks
Why not try some examples for ##f(x)## and see what happens?
What can R look like? Max degree, e.g.?
This formula you wrote $$f(x)=Q(x)(x-1)(x+1)+R(x)$$ says a lot if you know how to interpret it. Since (x-1) divides f(x) what can you say about whether (x-1) divides R(x)?
I believe this and together with the answer to the question of @haruspex will get you to the answer of the question.
In particular, what happens for ##f(x) = (x-1)##?
Yes, that's not bad place to start.
Thank you very much for the help PeroK, haruspex, Delta2, Factchecker
It seems that the problem is solved.. so I can show a solution in detail.
f(x) is divisible by (x-1):
f(x)=g(x)(x-1)...(1)
g(x) divided by (x+1), the remainder is g(-1):.
g(x)=p(x)(x+1)+g(-1)...(2)
So f(x)=(p(x)(x+1)+g(-1))(x-1)=p(x)(x+1)(x-1)+g(-1)(x-1)...(3)
f(x) divided by (x+1) the remainder is f(-1) . From (3)
f(-1)=g(-1)(-2)...(4)
f(x) divided by (x-1)(x+1), the remainder is g(-1)((x-1) . Because of (4), this is equal to f(-1)/(-2)(x-1) =f(-1)(1-x)/2
