Removal of snow during constant snowfall (flawed solution)
  • Thread starter Thread starter JSGandora
    Constant
The discussion centers on a snow removal problem involving a snowplow that begins clearing snow at noon after a steady snowfall starts earlier in the morning. The flawed solution incorrectly assumes the shape of the snow accumulation is a trapezoid, leading to an erroneous conclusion that snow began falling at 11:30 AM. The correct solution, derived using calculus, indicates that snow started falling approximately at 11:23 AM, based on the relationship between the snowplow's velocity and the time elapsed since snowfall began.
  • Understanding of calculus, specifically logarithmic functions and derivatives.
  • Familiarity with the concept of instantaneous rates and their applications in physics.
  • Knowledge of geometric shapes, particularly trapezoids, and their properties.
  • Ability to solve quadratic equations and interpret their results in real-world contexts.
  • Study the relationship between velocity and time in calculus, focusing on inverse relationships.
  • Learn about the application of logarithmic functions in real-world problems.
  • Explore the geometric interpretation of area under curves and its relevance to physics problems.
  • Practice solving quadratic equations and understanding their graphical representations.
Mathematics students, educators, and anyone interested in applying calculus to solve real-world problems involving rates of change and geometric interpretations.
JSGandora
A snowplow can remove snow at a constant rate (in cb. ft/min). One day, there was no snow on the ground at sunrise, but sometime in the morning it began snowing at a steady rate. At noon, the plow began to remove snow. It had cleared 2 miles of snow between noon and 1 PM, and 1 more mile of snow between 1 PM and 2 PM. What time did it start snowing?
At first I tried to do the problem without Calculus and I found an answer, however my answer does not match the correct solution answer and I am having trouble finding the flaw in my non-Calculus solution. Can someone help me find the flaw in my solution?
My Flawed Solution:
Let [itex]f[/itex] be the rate of snowfall and [itex]r[/itex] be the rate of snow removal. Like the AoPS solution, let noon be the time [itex]h[/itex] hours after the snow started falling. Let the width of the snowplow be [itex]w[/itex].
So in first hour after noon, the snowplow plowed [itex]r[/itex] amount of snow. In the second hour, it also plowed [itex]r[/itex] amount of snow. What is important is that it plowed the same amount of snow in the first and second hours.
Additionally, the instantaneous height of snow that is plowed at time [itex]t[/itex] after the snow started falling is [itex]tf[/itex] and thus the shape of all the snow that has been removed to be a trapezoid in the first and second hours.
The trapezoid that is plowed in the first hour has height [itex]2\text{ miles}[/itex] and bases [itex]hf[/itex] and [itex](h+1)f[/itex]. The trapezoid that is plowed in the second hour has height [itex]1\text{ mile}[/itex] and bases [itex](h+1)f[/itex] and [itex](h+2)f[/itex] and since the amount of snow that is plowed in the first hour is equal to the amount of snow plowed in the second hour, we must have the volumes of both trapezoids equal. So we have
[itex]w(2\text{ miles})\frac{hs+(h+1)s}{2}=w(1\text{ mile})\frac{(h+1)s+(h+2)s}{2}[/itex]
[itex]s2(2h+1)=s(2h+3)[/itex]
[itex]4h+2=2h+3[/itex]
[itex]2h=1[/itex]
[itex]h=\frac12.[/itex]
Thus the snow started falling exactly half an hour before noon which is [itex]11:30[/itex] AM, which does not match the correct solution.
Correct Solution:
Observe that the instantaneous velocity of the snowplow is inversely proportional to the time after the snow started falling, so [itex]\frac{\text{d}{s}}{\text{d}t}=\frac{k}{t}[/itex] for some constant [itex]k[/itex] where [itex]s[/itex] is the position of the snowplow and [itex]t[/itex] is the time after the snow started falling. Thus we have
[itex] \frac{\text{d}{s}}{\text{d}t}=\frac{k}{t}\implies s(t)=k\ln t+C[/itex]
for some constants [itex]C[/itex] and [itex]k[/itex].
Let noon be the time [itex]h[/itex] hours after the snow started falling, so we have
[itex]s(h+1)-s(h)=k(\ln h+1-\ln h)=2\text{ miles}[/itex]
and
[itex] s(h+2)-s(h+1)=\ln h+2 -\ln h+1 =1\text{ mile}[/itex]
so
[itex]2k(\ln h+2-\ln h+1)=k(\ln h+1-\ln h)[/itex]
[itex]2\ln\frac{h+2}{h+1}=\ln\frac{h+1}{h}[/itex]
[itex]\left(\frac{h+2}{h+1}\right)^2=\frac{h+1}{h}[/itex]
[itex]h^2+h-1=0[/itex]
[itex]h=\frac{-1+\sqrt{5}}{2}\approx 0.618[/itex]
so it started snowing [itex]0.618[/itex] hours before noon which is about 11:23 AM.
I do not understand your trapezoid argument and feel that herein lies the problem. Could you perhaps elaborate?
Edit: To be more specific and not require you to re-type the whole thing. Could you elaborate on the statement
Ohh, I believe I found the flaw, the shape is not a trapezoid because the distance traveled does not depend linearly on the time passed.
14K
