Removing cement-like substance from a white-cast iron
  • Thread starter Thread starter happycamper
    Iron
The discussion focuses on effective methods for removing cement-like substances from white-cast iron mixing paddles used in a pugmill. The paddles are made from various materials, including 27 Cr White Cast Iron and tungsten carbide hardfacing. Participants suggest using commercial cement removers that contain phosphoric and formic acids, which are less aggressive towards the metal compared to stronger acids like sulfuric or hydrochloric. Mechanical removal methods, such as hammering, are also recommended as a preliminary approach.
  • Understanding of wear rates and patterns in materials science
  • Familiarity with white-cast iron and its properties
  • Knowledge of chemical properties of acids, particularly phosphoric and formic acids
  • Experience with mechanical removal techniques in industrial applications
  • Research the effects of phosphoric and formic acids on white-cast iron and tungsten carbide
  • Investigate mechanical removal techniques for hardened cement on metal surfaces
  • Explore the guidelines provided by ACI 515.1R and ACI 201.2R-92 regarding acid use
  • Consult with local ready-mix concrete plants for practical insights on cement removal
Materials scientists, mechanical engineers, and industrial maintenance professionals involved in the maintenance and optimization of mixing equipment in construction and manufacturing settings.
happycamper
Hi all
I have kind of an odd question, it has been quite hard to find an answer for.
I'm doing a thesis comparing wear rates and patterns in low stress sliding abrasion between field conditions and labratory-based tests.
The field trial uses a quarry 'pugmill', which is essentially a giant mixer that combines roadbase and a cement (unsure exactly what type). The wearing parts are the mixing paddles, usually made from white-cast irons - for the thesis I'm testing four different types (OEM, hard-faced etc). For dust suppression, a water mist is used - however this causes a build up of hardened cement in patches on the paddles over time.
I was wondering what would the best way to remove this cement build up on the paddles would be - accurate before and after weights are required for wear-rates. Some of the paddles have smooth surfaces, and the cement can be removed easily enough with a chisel. However some surfaces (such as the tungsten carbide hardfacing) are quite rough and the cement is hard to completely remove.
Paddle materials:
1) 27 Cr White Cast Iron (OEM paddle)
2) CC1500 CrC wear plate overlay - 8mm hardface on 8mm backing plate on 20mm Hardox 400 base
3) 'Duaplate' CrC wear plate overlay - 8mm hardface on 8mm backing plate on 20mm Hardox 400 base
4) Tungsten Carbide Hardfacing - 4-5mm hardface on 32mm Hardox 400 base
I was thinking along the lines of an acid bath of some description, however I'm unsure what acid to use. Any other ideas, or nudges in the right direction would be appreciated as well
Thanks
p.s.
Picture of a pugmill (from google), take note of the mixing paddles.
[PLAIN]http://www.claymineadobe.com/auction/Pug-Mill-Paddles-x-40-ea..jpg
Commercial cement removers use some mixture of phosphoric and formic acids for this purpose.
Would this have a detrimental effect on the iron paddles?
And in addition, what sort of concentrations are the acids in cement removers?
The difficulty with strong acids such as sulphuric or hydrochloric is that they all too readily also attack the metalwork. The acids I mention are more benign, removing only a microscopic surface layer (you have to give something) but for instance phosphoric acid baths are used to passivate and prepare ferrous metal for painting.
You are correct that direct information on this subject is hard to find. It was a long time ago that I was involved with this - I suggest chatting to your local ready-mix concrete plant. In general I remember mechanical removal (hammering) was tried first.
Neville (Properties of Concrete) suggests that "concrete can be attacked below pH of 6.5, severe below 5.5, very severe below 4.5"
He also lists a number of possible acids. As do ACI 515.1R and ACI 201.2R-92
