Removing hyperlinks from pasted text on Physics Forums
  • Thread starter Thread starter gmax137
5 replies · 2K views
Education Advisor
[Moderator's note: Question spun off from another thread.]
Is there a quick way in PF to remove hyperlinks from cut&paste text? I don't feel good about posting embedded links.
Below, I pasted the text into notepad++ and it preserves text only. So it works, but it is another step, with another software.
The crew of the Dali, the ill-fated vessel that slammed into the Francis Scott Key Bridge in Baltimore, are still onboard the cargo ship — and they could be stuck there even longer as authorities continue to assess the situation.
Two pilots and 21 crewmembers were manning the Dali on Tuesday when it rammed into one of the bridge’s support pillars, causing the 1.6-mile span to crumble and plunge into the Patapsco River.
That's what I do. It has the additional advantage of eliminating any unwanted formatting, such as giant header text, etc.
But yes, there is a context menu that pops up when you click on the text that has a 'remove link' option:
Reply
Paste text without formatting with Shift + Ctrl + V instead of just Ctrl + V. It should work with any program, not just your browser, and certainly not just with PF. It works with Windows & Linux; Mac uses Option+Shift+Command+V according to the link below.
Ctrl+Shift+V Is the Best Shortcut You're Not Using
Reply
  • Wow
Wow, thanks Jack, I never knew that one!
"Copy PlainText" is a Firefox extension that removes the formatting from the selection before copying/pasting to/from the Clipboard.
Sunuvagun. You have potentially saved me hours of time, amoritized over the rest of the life. Thank you, sir!
