Reparameterizing a Curve Using Arc Length as the Parameter
  • Thread starter Thread starter roadrunner
    Curve
12 replies · 3K views
roadrunner
"Reparameterize the curve with respect to the arc length measured from the point where t=0 in the direction of increasing t. r(t)=e^(2t)*cos2t i +2 j + e^(t2)*sin2t k"
the method we were taught is take r'(t) and then find |r'(t)| and then integrate that.
but in every example we were given, the derivative was a real number, not a function (IE: 12, sqrt(23) etc)
i took the derivative and got [-2e^(2t)sin(2t)+2te^(2t)cos(2t)]i +0j + [2e^(2t)cos(2t)+2te^(2t)sin(2t)] k
then |r'(t)|=(after simplifying it i got) =2e^(2t)sqrt(1+t^2) which seems nice and simple now...but how to i integrate that...
the form they used was s=s(t)=integral from 0-t of |r'(u)|du
for every other problem of this nature
Where did the t's in front of the exponentials in your derivative come from? They definitely shouldn't be there.
this derivative? [-2e^(2t)sin(2t)+2te^(2t)cos(2t)]i +0j + [2e^(2t)cos(2t)+2te^(2t)sin(2t)] k
ill just do the firts part as "k" is the same as "i"
f'(t) "e^(2t)*cos2t"
u'v*v'u corrrect?
2t*e^t*cos2t + e(2t)*-sin2t
or did i do that wrong?
i thought the derivative of e^(2x)=2xe(2x) but maybe its juts 2e^(2x)? (this is calc 3 and i took calc 1 and 2 2 years ago so i kinda forget them! :(
Yes, it's just 2e^(2x). It's a pretty easy chain rule.
so doing it the RIGHT way i get the derivative is
[-2e^(2t)sin(2t)+2e^(2t)cos(2t)]i +0j + [2e^(2t)cos(2t)+2e^(2t)sin(2t)] k
which gives me a simplified |r'(t)| of 2e^(2t)sqrt2?
that look right now
and assuming that's right i would just integrate 2e^(2t)sqrt2? and get e^(2t)sqrt2? and then evaluate from o to t?
which would give me e^(2t)sqrt2-sqrt(2)
So what's your new parameter t? So far, you only have arc length.
e^(2t)sqrt2-sqrt(2) would be the arc legnth
so the new parameter is since s=e^(2t)sqrt2-sqrt(2)
s+sqrt2=e^(2t)sqrt2
(s+sqrt2)/sqrt2=e^(2t)
ln((s+sqrt2)/sqrt2)=2tlne
ln((s+sqrt2)/sqrt2) /2 =t
original e^(2t)*cos2t i +2 j + e^(t2)*sin2t
final e^(ln((s+sqrt2)/sqrt2))*cos(ln((s+sqrt2)/sqrt2)) i +2 j + e^((ln((s+sqrt2)/sqrt2)))*sin(ln((s+sqrt2)/sqrt2))
Gotta confess, I'm not checking all the details for you. But it looks about right. You can check yourself. Take d/ds and see if you get a unit vector. BTW you could have skipped the integration constant. Why?
what do you mean by the integration constant? the 2?
No, the sqrt(2). The lower limit in your integral. It doesn't hurt you to include it though. Don't worry about it.
you mean the sqrt2 is (s-sqrt2)/sqrt2 ??
can you explain why i don't need it pleasE? :D
I mean there is not much difference between writing s+sqrt(2) and just s. It's just a change in the origin of the parametrization.
