Replacing stoi in C++ program for converting string to integer
  • Topic: C/C++
  • Thread starter elmessican
    C++ Program
4 replies · 6K views · last reply
elmessican
What can I use to replace stoi since the homework program won't accept it? I'm trying to read a string and display it as an integer. I know I have to use stringstream but have no idea how.
Code:
//ReadData.cpp
#include <iostream>
#include <cstring>
#include <cstdlib>
#include <string>
#include <vector>
#include <sstream>
#include <iomanip>
#include <stdlib.h>
using namespace std;
int main() {
    //Define the required variables
    string title, head1, head2, s;
   vector<string> data;
   vector<int> point;
    //Prompt and read the title of the data
    cout << "Enter a title for the data: " << endl;
    getline(cin, title);
    cout << "You entered: " << title << endl;
    cout << endl;
    //Prompt and read the headers of two columns
    cout << "Enter the column 1 header: " << endl;
    getline(cin, head1);
    cout << "You entered: " << head1 << endl;
        cout << endl;    cout << "Enter the column 2 header: " << endl;
    getline(cin, head2);
    cout << "You entered: " << head2 << endl;
        cout << endl;    //Use while loop to read the data points until user enters -1
    while (1) {
         cout << "Enter a data point (-1 to stop input): " << endl;
         getline(cin, s);
         if (s == "-1") {
             break;
         if (s.find(',') == -1) {
             cout << "Error: No comma in string." << endl;
               cout << endl;
         else {
             int count = 0;
             for (int i = 0; i<s.length(); i++) {
                 if (s.at(i) == ',') {
                      count++;
                      if (count > 1) {
                          break;
             //If the input have single ',', then display the data string and data integer
             if (count == 1) {
                 data.push_back(s.substr(0, s.find(',')));
               point.push_back(stoi(s.substr(s.find(',') + 1, s.length() - 1)));
                 cout << "Data string: " << s.substr(0, s.find(',')) << endl;
                 cout << "Data integer: 6" << stoi.s.substr(s.find(',') + 1, s.length() - 1) << endl;
                  cout << endl;
             else {
                 //Display the appropriate error message
                 cout << "Error: Too many commas in input." << endl;
                  cout << endl;
    //Display the data in the required format
    cout << "\t" << title << "\t" << endl;
    cout << head1 << "\t|\t" << head2 << endl;
    for (int i = 0; i<data.size(); i++) {
         cout << data[i] << "\t|\t" << point[i] << endl;
         cout << data[i] << " ";
         for (int j = 0; j<point[i]; j++) {
             cout << "*";
         cout << endl;
    return 0;
As I could see you've used stoi incorrectly.. are you sure it's not
Code:
stoi(substr(...))
You've used
Code:
stoi.substr(...)
stoi - C++ Reference
If you want to use string streams,
Code:
string tempstring = substring(...);
int tempint;
stringstream strstream;
strstream << tempstring;
strstream >> tempint;
I changed that and I still get this error apparently the compiler is not up to date with c++11 and doesn't recognizes 'stoi', how can I add the stringstream to my code. It would be a great help if you could show me. Thanks.main.cpp:97:78: error: 'stoi' was not declared in this scope
Oh yeah std::stoi is a c++11 feature so unless your complier doesn't support c++11 you won't be able to use it. I have given you an example on how to use the stringstream, is there anything not clear about it?
Yea I think I get it but i just don't know how or where to added to my code lol
