Replacing two couples with one equivalent couple when P=0
  • Thread starter utkarshakash
    Couple Net
2 replies · 4K views · last reply
utkarshakash
If P=0, replace the two remaining couples with a single equivalent couple, specifying its magnitude and the direction of its axis.
Position vector of B(rb)=0.3i
Similarly, rd=0.16j+0.17k
∠GCF=atan(16/30)=28.07°
∠DEF=atan(DF/FE)=45°
Then I tried to resolve the forces into its individual components. For 34N force applied at B, in vector form,
[itex]34 \cos 28.07 \hat{i}-34 \sin 28.07 \hat{j}-34 \cos 45 \hat{k}[/itex]
For the other force at B, I can write -18k.
At D, [itex]-34 \cos 28.07 \hat{i}+34 \sin 28.07 \hat{j}+34 \cos 45 \hat{k}[/itex]
Now I take moments of all the above forces about the origin which gives me
1.13i + 7.51j
the magnitude of which is given by [itex]\sqrt{1.13^2+7.51^2} = 7.59[/itex]
which is incorrect according to answer key.
  • 3D diagram of a triangular prism with vertices labeled A, B, C, D, E, F, showing forces 34 N and 18 N at points B, D and G, load P at A and C, and dimensions 170 mm, 150 mm and 160 mm.
Are you sure angle DEF is 45 degrees? It doesn't look it from the figure.
You calculated the components of the 34 N force incorrectly. The 34 N forces are parallel to the vector connecting D and E or F and B. Find the direction of those vectors from the coordinates of the points. Multiply the magnitude of the force with the unit vector in the appropriate direction. ehild
