Resistance between points A and B with three resistors
  • Thread starter n77ler
    Resistance
n77ler
[SOLVED] Finding Resistance
A number of resistors of values R1 = 3.8 Ω, R2 = 80.0 Ω, and R3 = 20.0 Ω are connected as shown in the figure. What is the resistance between points A and B?
Im confused because all I've been calculating is the equivalent resistance, what is the difference between the two?
  • Circuit schematic of a resistor network between terminals A and B: two rows of resistors labelled R1 joined by a middle rung R2 and an outer rung R3 on the right.
They are just asking for the equivalent resistance of that network, as seen at the entry points A & B. Just use your series & parallel combination rules to reduce the network to a single (equivalent) resistor between A & B, and you will have your answer.
The Four R1 and R3 are in series thus those five resistors to the right can be combined by adding the value...(4*3.8+20)=35.2Ω
That resistance is in parallel with the R2 thus the combination of the five and this resistor is equal to 1/(1/35.2+1/80) = 24.4Ω (3sf)
Now the total becomes this plus 2*R1
Total = 24.4+3.8*2 = 32.0Ω (3s.f.)
Just incase you were still stuck, that and I like to go back to some easy electronics now and again to remind me that my head hasn't exploded :)
You shouldn't give out the answers. We're not here to give solutions, but rather how to figure out a problem.
My Apologies, I was only going from what I saw in the rest of the forum.
