Resonance & Tubes: Frequency of Tuning Fork
  • Thread starter Thread starter m.l.
    Resonance
The discussion focuses on calculating the frequency of a tuning fork using resonance in an open vertical tube filled with water. Resonance occurs at two water levels: 17 cm and 49 cm from the top of the tube. The difference in these levels is 32 cm, which is used to determine the wavelength (λ) as 0.70 m. Using the speed of sound at 343 m/s, the frequency (f) is calculated to be 490 Hz.
  • Understanding of wave mechanics and resonance
  • Familiarity with the speed of sound in air (343 m/s)
  • Knowledge of the relationship between frequency, wavelength, and speed (f = v/λ)
  • Concept of open and closed tube resonance
  • Study the principles of resonance in open and closed tubes
  • Learn about the calculation of frequency using different wave equations
  • Explore the effects of temperature on the speed of sound
  • Investigate practical applications of tuning forks in acoustics
Students in physics, educators teaching wave mechanics, and anyone interested in the practical applications of sound waves and resonance phenomena.
m.l.
An open vertical tube is filled with water and a tuning fork vibrates over its mouth. As the water level is lowered in th etube, resonance is heard when the water level has dropped 17 cm, and again after 49 cm of distance exists from the water to the top of the tube. What is the frequency of the tuning fork?
lamda=2xlength, f=v/ lamda, speed of sound is 343m/s
49-17=35
lamda=2l (or is it lamda=4l cause its a closed system?)
=2x.35
=0.70m
f=v/lamda
=343m/s/0.70m
= 4.9x10 exponent 2 Hz?
m.l. said:
1. Homework Statement
3. The Attempt at a Solution
49-17=35
Isn't 49 - 17 = 32 ?
9K
