Resultant Force and Direction using Parallelogram Law
  • Context: Engineering
  • Thread starter Thread starter Nova_Chr0n0
    Force Resultant force
The discussion revolves around the application of the parallelogram law to determine the resultant force and its direction in a physics problem. Participants explore the calculations involved in using both the parallelogram method and the component method to analyze the forces at play.
  • One participant computes the angle α and uses the cosine law to find the resultant force R and the angle θ, expressing concern about a negative angle value.
  • Another participant points out that the diagram shows the resultant force below the x-axis, which contradicts the calculated angle β that suggests it should be above the x-axis.
  • A participant mentions a preference for using vector components over the parallelogram method, arguing that calculations should precede drawing the diagram to avoid inaccuracies.
  • One participant acknowledges correcting their diagram to show the resultant force above the x-axis after receiving feedback.
  • Another participant notes that if the magnitude of one force were smaller, the angle of the resultant force with respect to the x-axis would be greater.
  • A participant explains the utility of the parallelogram law for constructing the resultant geometrically, emphasizing that it can provide an approximate direction without a calculator.
  • One participant highlights the importance of drawing vectors to scale when using the parallelogram rule, noting a common mistake in sketching vector lengths inaccurately.
Participants express differing views on the accuracy of the initial diagram and the methods used for calculating the resultant force. There is no consensus on the preferred method, as some favor the component method while others discuss the parallelogram approach.
Participants mention various assumptions related to the magnitudes and angles of the forces involved, as well as the importance of accurately representing vector lengths in diagrams. The discussion does not resolve these assumptions or the implications they have on the calculations.
This discussion may be useful for students or individuals interested in understanding the application of vector addition methods in physics, particularly in resolving forces and analyzing resultant directions.
Nova_Chr0n0
2-79. Use the parallelogram law to determine the magnitude of the resultant force acting on the pin. Specify the resultant's direction, measured from the x-axis.
Cosine Law
Sine Law
Picture above is the complete question. I want to ask about the problem where I would use the parallelogram method. Here is my FBD:
I start off by computing the angle alpha:
α + α + 105 +105 = 360
α = 75 degree
After that, I now use cosine law to solve for the resultant force:
R=[(80)^2+(50)^2-2(80)(50)cos(75)]^(1/2)
R = 82. 640 lb
For the resultant angle with respect to the x-axis, I tried computing for angle beta first:
[sin(β)/80] = [sin(75)/82.640]
β = 69.239
To get theta, I now subtract angles and got:
θ = 90-30-69.239
θ = -9.239 degree
Here where my question starts, my initial thought is that the negative value is acceptable since the angle I'm finding is below the horizontal. But when I did the component method instead of the parallelogram method, I got the position of theta to be wrong.
USING COMPONENT METHOD:
Rx = 80sin(45)+50sin(30) = +81.569 lb
Ry = 80cos(45)-50cos(30)= +13.267 lb
Based on this value, The x component of the resultant force is (+) and the y component is also (+). So the resultant force should be above the x-axis. But in the drawing of my parallelogram, it is below the +x-axis. Is my drawing of the parallelogram inaccurate? or am I missing an important information/knowledge here? If I continue the solution for the component method, I still got 9.239 degree as my answer. But the position the theta in my drawing worries me.
Your diagram is not quite right, because you've shown the resultant force is below the x-axis. You got ##\beta = 69## degrees, which gives a resultant angle of about ##9## degrees above the x-axis.
Personally, I would use vector components to calculate the force before I drew the diagram. For the good reason that, until you've done the calculation, you don't know where to draw the resultant force.
PS I could look up what the "parallelogram" law is, but it's not something I use. The cosine rule is useful; as is the sine rule.
Thanks! Upon reviewing it, my diagram is actually wrong. I have now corrected it and the resultant drawing using parallelgoram method now lands on the upper part of the x-axis. I'm also not a fan of using parallelogram espsecially when resultants are involved. But well, I got to follow the instruction given.
Nova_Chr0n0 said:
... I have now corrected it and the resultant drawing using parallelogram method now lands on the upper part of the x-axis.
Note that if the magnitude of the 50 lbf was smaller, the angle of the resultant force respect to the x-axis would be greater.
One reason to use the parallelogram law (as in 2-79) [tails together, draw parallels through the tips of the vectors, then construct the diagonal from the tails to the opposite corner] is to construct the resultant with geometrical tools (a ruler), which can be approximated with a sketch. (No calculator is needed to get the [approximate] direction... one can develop some geometric intuition for the resultant.)
Use the side-lengths and angles with either components (as in 2-80) or the sine and cosines laws for a more precise calculation.
You've hopefully already realized this, but I'll explicitly state it for the benefit of other students who run across this thread since it's a common mistake in my experience. You sketched the two vectors with approximately the same length, but from the information given, you should have made the bottom vector about 2/3 the length of the other vector. When you're making a sketch and using the parallelogram rule, it's critical that you draw the vectors to scale.
11K
