Returning values in array in c
  • Thread starter konvictx
    Array
4 replies · 3K views · last reply
konvictx
Code:
#include<stdio.h>
#include<conio.h>
float average(float[],float );
float highest(float[],float );
float lowest(float[], float );
void main (void)
float temper[15];
float x,n, y, z;
int  day;
clrscr();
printf("enter the no.days to read temperature for=\n");
scanf("%d",&n);
for(day=0; day<n; day++)
 printf("temperature for day%d=",day+1);
 scanf("%f",&temper[day]);
x=average(temper,n);
printf("average temperature is=%.2f\n",x);
y=highest(temper,n);
printf("highest temperature is=%.2f\n",y);
z=lowest(temper,n);
printf("lowest temperature is=%.2f\n",z);
getche();
float average(float temper[],float n)
int sum=0.0,x;
float average;
for(x=0; x<n; n++)
 sum+=temper[x];
 average=sum/n;
 return (average);
float highest(float temper[],float n)
float highest;
int y;
highest=temper[0];
for(y=0; y<n; y++)
if(highest<temper[y])
highest=temper[y];
return(highest);
float lowest(float temper[],float n)
float y,lowest=temper[0];
for(y=0; y<n; y++)
if(lowest>temper[y])
lowest=temper[y];
return(lowest);
hy my code is not returning value of average minimum and maximum temperature. what can i do now?
What result does your code actually show for maximum, minimum and average, for a specified small set of temperature values? (give a specific numeric example)
Code:
void main (void)
   float temper[15];
   float x,n, y, z;
   int  day;
   clrscr();
   scanf("%d",&n);
You are declaring n as a float, but are attempting to read an int in scanf. Change the declaration of n to int.
I didn't notice any other errors, but I only gave your code a quick scan.
There is a Data Typical Mistake in float average();
You see, when you declare int sum = 0.0; sum is of int data type.
Now, when you store float into int, as in sum+=temper[x];
sum will truncate/delete all the decimal values and only sum integer part.
sum/n is ok, it will give a decimal float value.
If you declare n as int, and fix the datatypes in all of the functions, you still don't have to bother about sum/n, because sum is now of float type.
So, do all those edits, and tell us how's it going.
Editted:
Code:
#include<stdio.h>
#include<conio.h>
float average(float[],int );
float highest(float[],int);
float lowest(float[], int);
void main (void)
float temper[15];
float x, y, z;
int  day, n;
clrscr();
scanf("%d",&n);
z=lowest(temper,n);
getche();
float average(float temper[],int n)
 int x;
 float sum=0.0;
float average;
for(x=0; x<n; n++)
 sum+=temper[x];
 average=sum/n;
 return (average);
float highest(float temper[],int n)
float highest;
int y;
highest=temper[0];
for(y=0; y<n; y++)
highest=temper[y];
return(highest);
float lowest(float temper[],int n)
for(y=0; y<n; y++)
lowest=temper[y];
return(lowest);
Now that should do.
