Rewrite Q=A+B+C+D using only 2-input NAND gates
  • Thread starter Thread starter thomas49th
    Logic
10 replies · 8K views · last reply
thomas49th
Taking the statement Q = A + B + C + D
Rewrite using only NAND (2 inp) and NOT gates
Well I want to do it all in NAND gates - because we can easily tie NAND inputs to make it a NOT
[tex]\overline{AA} = \overline{A}[/tex]
At the moment Q is equal to true if A OR B OR C OR D is true.
I can change OR into a NAND gate quite easily.
[tex]\overline{\overline{(x+y)}} = \overline{\overline{x}\bullet\overline{y}}[/tex]
which is
[tex]x+y = \overline{\overline{x}\bullet\overline{y}}[/tex]
this means I obtain
[tex]\overline{\overline{A}\bullet\overline{B}\bullet\overline{C}\bullet\overline{D}}[/tex]
But this has NOTs and AND logic in, not NAND. I need expressions in NAND which is [tex]\overline{AB}[/tex]
Any hints?
Thanks
Thomas
Start by using your identity
[tex] x+y = \overline{\overline{x}\bullet\overline{y}}[/tex]
on (A+B) + (C+D).
Still get to the same place:
[tex](A+B)+(C+D)[/tex]
[tex]\overline{\overline{A}\bullet\overline{B}} + \overline{\overline{C}\bullet\overline{D}}[/tex]
[tex]\overline{\overline{\overline{\overline{A}\bullet\overline{B}}} + \overline{\overline{\overline{C}\bullet\overline{D}}}}[/tex]
[tex] \overline{\overline{A}\bullet\overline{B}\bullet\overline{C}\bullet\overline{D}}[/tex]
Hmmm :(
Was I meant to perform some other manipulation part way?
Thanks
Thomas :)
Here's how I sometimes think of these things. Let's denote the nand function of A and B by n(A,B). So
[tex]n(A,B) = \overline{A\cdot B}[/tex]
So your equation
[tex] <br /> x+y = \overline{\overline{x}\bullet\overline{y}}<br /> [/tex]
becomes
[tex]A + B = n(\overline A,\overline B)[/tex]
or "the sum becomes the nand of the complements" (DeMorgans rule). This gives
[tex](A+B) + (C + D) = n(\overline{A+B},\overline{C+D})[/tex]
Now apply the same rule to the sums on the right side. This will leave you an expression with only nands and complements, which can be expressed with inverters.
[tex] (A+B) + (C + D) = n(\overline{n(\overline{A},\overline{B}}),\overline{n(\overline{C},\overline{D}})[/tex]
Which is the same as
[tex] \overline{\overline{\overline{\overline{A}\bullet\overline{B}}} + \overline{\overline{\overline{C}\bullet\overline{D }}}}[/tex]
Yes. So are we done here? Do you see how to implement it as a nand and inverter circuit?
I think so
[tex] <br /> \overline{\overline{A}\bullet\overline{B} + \overline{C}\bullet\overline{D}}<br /> [/tex]
is the same as
[tex] <br /> (A+B) + (C + D) = n(\overline{n(\overline{A},\overline{B}}),\overline {n(\overline{C},\overline{D}})<br /> [/tex]
I just can't see how to get into the NAND form: [tex]\overline{A \bullet B}[/tex]
instead of using the new implementation you use n(\overline{A},\overline{B}})
Thank
Thomas
Thank
Thomas
I think all the overlines get very confusing. But you can use that n form to immediately draw a nand and inverter circuit. The outside n gives you the nand of two things. What two things? The invert of the two inside nands. So I would start by drawing the output nand gate with inverters at its two inputs. What is on the inputs of these inverters? The inside nands. So put a nand in front of each inverter with their inputs which are the inverted A,B,C, and D inputs.
To express it as in logic notation in terms of just nands and complements, the n expression could be written like this:
[tex]\overline{\left(\overline{\left(\overline{\overline A \cdot \overline B}\right)}\right)<br /> \cdot \left(\overline{\left(\overline{\overline C \cdot \overline D}\right)}\right)}[/tex]
Here the big parentheses with the complement over them represent a nand gate, and its inputs are the complments of the nand gates represented by the inner parentheses. The second level nands have the complents of A,B,C, and D for inputs.
[tex]\overline{\left(\overline{\left(\overline{\overline A \cdot \overline B}\right)}\right) \cdot \left(\overline{\left(\overline{\overline C \cdot \overline D}\right)}\right)}[/tex]
is the same as
[tex]\overline{\overline{\overline{\overline{A}\bullet\overline{B}}} + \overline{\overline{\overline{C}\bullet\overline{D }}}}[/tex]
You've just put brackets in seperating the complements that COULD cancel?
Right.
Excellent :)
is the same as
Right.
Excellent :)
You don't want to cancel the complements. Your expression has a "+" in it which represents OR. It may be logically equivalent but it doesn't give a nand and inverter representation any more than A + B + C + D does.
