Right Hand Rule: Proton or Electron?
3 replies · 4K views · last reply
Air
For this given diagram, determine whether the particle is a proton or an electron.
Diagram of a charged particle's U-shaped path entering a shaded region from above, with the field B shown pointing out of the page (dot in circle).
2. The attempt at a solution
Considering at the point where it enters the material.
Using RHR, Velocity is downwards (First Finger), Field is outwards (Middle Finger), Thumb points left but the force is supposed to be to the right so it's an electron.
3. The Problem encountered
The answer says that it's a proton but how can that be. Am I doing my RHR correctly? Can someone explain how it works. Thanks in advance.
Why is force supposed to be towards the right? You correctly found that v x B points left at the point where the particle enters the field. The force is F = q(v x B), so if the particle is positively charged, the force will be towards the left and the particle will be deflected towards the left. That's what happens in the picture, so it must be a proton. If q was negative, it would have been deflected towards the right.
For F=Bil, which fingers represent which part?
Is it first finger current, middle finger field and thumb is force?
