Right triangle with four jointed links
The discussion revolves around solving a geometry problem involving a right triangle ABCD formed by four jointed links, with a focus on finding the height x when a = 50 mm. The initial approach involves using the Pythagorean theorem to determine the length of the sides, leading to the calculation of x as approximately 86.60 mm. Participants discuss deriving the angle DCB and recognizing that the smaller triangle formed is isosceles, which complicates the calculations. The final calculations suggest that the height x could be around 46.53 mm after further analysis. The conversation emphasizes the relationship between angles, height, and hypotenuse in right triangles.
chawki
A right triangle ABCD is formed from four jointed links. The joint D at the midpoint of the hypotenuse is pushed until it lies on the leg AB.
Find the height x when a = 50 mm
give me a hint please cause I'm lost :mad:
Well, if I was given a right triangle and the length of two of the sides, I would first find out what the length of the third side is, Pythagoras.
ok, let the distance AB=x
(2a)2=a2+x2
x2= 4a2-a2=3a2
x=\sqrt{}3 * a
x=86.60mm
and then DB=86.60-50
DB=36.6mm.
But then?
I would find the angle DCB using the initial right triangle, then note that the new, smaller triangle is isosceles because DC=(2a)/2 and CB=a. Then use the fact that the altitude from C bisects angle DCB and creates two new right-triangles...you then have a relation between angle, height, and hypotenuse.
sounds complicated!
How can we find the angle DCB ?
hello
AB-a=86.6-50=36.6mm
now, a2=x2+(36.6/2)2
x=46.53mm ?
