Rocket travels along parabolic path (RECTANGULAR COMPONENTS)
A rocket follows a parabolic path defined by the equation (y-40)²=160x, starting at an altitude of 40m and reaching 80m. The vertical velocity component is constant at 180 m/s, leading to calculations for the horizontal position at y=80, which results in x=10. The discussion reveals confusion in calculating the total velocity, with attempts to differentiate the trajectory equation and find time to reach 80m. The calculated velocities varied, with one participant arriving at 193.7 m/s while the expected result was 201 m/s. The conversation emphasizes the importance of correctly applying kinematic equations and understanding the relationship between time, position, and velocity components.
patflo
When a rocket reaches an altitude of 40m it begins to travel along the parabolic path (y-40)^2=160x, where the coordinates are measured in meters. If the component of velocity in the vertical direction is constant at vy=180m\s, determine the magnitudes of the rockets velocity and acceleration when it reaches an altitude of 80m.
position: r=x*i+y*j (where i and j are the unitvector)
velocity: v=dr\dt
acc: a=dv\dt
lets say i tried for about 4 hours to get a concept to solve this. :(
first i put in in the equation for the motion path for y=80 to get x=10
second: position vector for point A (x=0,y=40) and point B (x=10 y=80)
third: to get the distance betwee A and B i subtract the 2 position vectors.
fourth: v=dr\dt to get the velocity
mazbe its the wrong way because the answer should be v=201 m\s and mines was 254 m\s.
i don't know where my mistake is...is the way of thinking right?
I don't how you found out dr/dt without separating out the equations for motion on x,y-axes w.r.t time from the trajectory equation.
Velocity on y-axis is constant so y=180t.
Put in trajectory eqn. to eliminate y then differentiate w.r.t. x. This will be velocity on x-axis. Add vectorially for complete velocity.
Or you could directly differentiate the trajectory equation w.r.t time. dy/dt is known, dx/dt can be found out and then added vectorially.
velocity: v=dr\dt
acc: a=dv\dt
Notice that eqn#2 has a variable in it that is defined in eqn#1. If you plug this definition from #1 into #2, what equation do you get for the velocity?
ok i tried out this:
d/dt (y-40)²=d/dt 160x
=> dx/dt=405t-90
v=vx*i+vy*j
v=(405t-90)*i+180j
but how can i find the magnitude? since in the equation for v there is still the variable "t".
Can you now find out how much time it takes for the projectile to reach a height of 80m?
may answer would be:
for the equation of path i put in y=180t and x=10 (when y=80 x=10)
then i get a quadratic function in t.
the result for t= 0.4s
i put that in v and get v=72i+180j
for magnitude: v=193,7 m/s
but as result there should be 201 m/s
t=(distance on y-axis)/(Speed on y-axis)
This is 40/180=0.22s.
thank you very much!
  • · Replies 16 ·
  • · Replies 42 ·
  • · Replies 53 ·
