Roots of a fourth degree polynomial
The discussion centers on solving the quartic equation z4 - z2 + 1 = 0 in the complex plane. Participants identify that the equation can be treated as a quadratic in the form of x = z2, leading to the quadratic x2 - x + 1 = 0. The roots of this quadratic are derived using the quadratic formula, yielding complex solutions. The sum of two roots is determined to be ±√3 or ±i, confirming that the sum of the roots can be simplified without needing to calculate all roots explicitly.
  • Understanding of complex numbers and their properties
  • Familiarity with quadratic equations and the quadratic formula
  • Knowledge of Vieta's formulas for roots of polynomials
  • Ability to convert complex numbers to polar form
  • Study the application of Vieta's formulas in polynomial equations
  • Learn about the polar representation of complex numbers
  • Explore advanced techniques for solving quartic equations
  • Investigate the geometric interpretation of complex roots
Mathematics students, educators, and anyone interested in complex analysis and polynomial equations will benefit from this discussion.
V0ODO0CH1LD
z^4 - z^2 + 1 = 0 is an equation in ℂ.
Which of the following alternatives is the sum of two roots of this equation:
(i) 2√3; (ii) -(√3)/2; (iii) (√3)/2; (iv) -i; (v) i/2
All I know is that the sum of all roots should equal 0, because that's the coefficient in front of the second highest degree term. And that the sum of the roots squared should equal 2, because that is the coefficient of the second highest degree term plus -2 times the third highest degree term.
The equation is quadratic in form. Let x = z2 and use the quadratic formula to find values of x (= z2).
No, the coefficient of the z2 term is -1, not 0.
It is a quadratic equation for z2. Solve it, then take the square roots of the solutions.
ehild
Okay, so I said x = z^2 in z^4 - z^2 + 1 = 0 and solved it as if it were a quadratic:
x^2 - x + 1 = 0 <=> (x - (1/2))^2 + 3/4 = 0
(x - (1/2))^2 = -3/4 <=> x - 1/2 = ±√(-3/4)
x = ±√(3)i/2 + 1/2
Now I can just square the roots of the equation for x and I get the roots of the equations for z?
Wait, ehild said I should take the square root of the roots. Why!?
x = ±√(3)i/2 + 1/2
Think about what you're doing. If you square x, you'll get z4. You want z.
Wow, thanks! I feel kinda of stupid now.. Anyway, I got to z = √(±√(3)i/2 + 1/2). Which means the sum of two roots of the equation could equal √(√(3)i/2 + 1/2) + √(-√(3)i/2 + 1/2). Any tips on how to simplify this to a point where it looks like one of the answers in the original question?
I don't know what you did to get the above.
I think the best way to go is to work with x = 1/2 ± i (√3/2), and write this in polar form, or r(cosθ + i sinθ). Here r = 1, so that simplifies things a bit, and the angles should be pretty easy to calculate. Getting a square root is pretty easy - you just take the square root of the magnitude (r) and divide the angle by 2.
For example, consider the complex number i, which in polar form is 1(cos ##\pi/2## + i sin ##\pi/2##). √i = 1(cos ##\pi/4## + i sin ##\pi/4##) = (√2/2) + (√2/2)i. This is one of the square roots of i. You can verify this by multiplying (√2/2) + (√2/2)i by itself.
Rather than actually calculating the roots, a much quicker way to do this would be to use the "sum of roots" and "product of roots" formulae for a quadratic. Let two roots of the quartic be z_1 and z_2.
Then you know that:
z_1^2 + z_2^2 = 1
z_1^2z_2^2 = 1
Now use those equations and figure out what values {(z_1 + z_2)}^2 can take, and take the square root of that. There's only one choice that matches.
The quartic, z4 - z2 + 1, can be expressed as the product of two quadratics. Because of symmetry we can suppose that they are of the following form, where a and b are real coefficients.
\displaystyle z^4-z^2+1
\displaystyle =(z^2+az+1)(z^2+bz+1)
\displaystyle =z^4+(a+b)z^3+(2+ab)z^2+(a+b)z+1​
Equating coefficients of powers of z gives a+b=0 and 2+ab=-1.
These can be solved for a & b.
The existing posts, noting that you don't actually need to find all the roots, are the right way to go. But fwiw, the easiest way to spot the simplification is to look at it geometrically. Where in the plane is 1 + i√3? What is that in (r, θ)?
If I solve for a and b on those I would get +√3 and -√3 which add up to 0 which is not one of the answers.
Then you know that:
z_1^2 + z_2^2 = 1
z_1^2z_2^2 = 1
I don't get the last thing. You mean to find the roots of (z^2)^2 - z^2 + 1 = 0 as if they were the roots of a quadratic and then take the square root of those?
EDIT: sorry, I meant find the roots of an equation like x^2 - x + 1 = 0 and take the square root of those!
\displaystyle \sqrt{3}\ \ \text{ and }\ -\sqrt{3}\ are not the roots of anything in this problem. They're the coefficients of z in the respective quadratics which factor the given quartic in this problem.
So, find the roots of each of those quadratics:
\displaystyle (z^2+\sqrt{3}z+1)\ \ \text{ and }\ (z^2-\sqrt{3}z+1)\ .​
This ia not as elegant a solution as those offered by others, but it does work.
Once you get the answer this way, go back and see how the suggestions of others also lead you to the answer.
It is correct, the roots are the square roots of either 1/2+i\sqrt{3}/2 or 1/2-i\sqrt{3}/2 . You know that a complex number can be written in the form r(cos(θ)+isin(θ)). What are r and theta?
You have learned something about the roots of a complex number. What was it?
ehild
Yeah, the roots are:
+ cos (π/6) + sin(π/6)i;
+ cos (π/6) – sin(π/6)i;
– cos (π/6) + sin(π/6)i;
– cos (π/6) – sin(π/6)i;
Which when added give ±√3 or ±i.
But according to what the others have said, I didn't need to actually find the roots in the first place. I can see how the other ways (Curious3141's, SammyS', Mark44's) to get the roots would work. I just don't see how I could have used those properties of quadratics to find the sums.
Curious' method gives the sum of roots directly.
From the quadratic equation for z2 you get that z12+z22=1 and z12z22=1 (Vieta's formulas). The second equation means that z1z2=±1.
(z1+z2)2=z12+z22+2z1z2=1±2.
ehild
Yes, this is correct. (Well, the sum can also be zero.)
As for my method, it did involve finding all of the roots. As follows:
\displaystyle =(z^2+\sqrt{3}z+1)(z^2-\sqrt{3}z+1)=0​
So that \displaystyle \ z^2+\sqrt{3}z+1=0\ \ \text{ or }\ z^2-\sqrt{3}z+1=0\ .
Using the quadratic formula to solve those gives:
\displaystyle z=\frac{-\sqrt{3}\pm i }{2}\ , \ \ z=\frac{\sqrt{3}\pm i }{2}\ .​
