Rosetta's comet mission discussion thread
205 replies · 37K views · last reply
https://agu.confex.com/agu/fm14/webprogrampreliminary/Session1556.html
Click for numerous abstracts to be submitted to the AGU meeting in San Francisco, December 15-19.
"The session welcomes papers on preliminary results from this Rosetta characterization, mapping and landing phase, including simulation and theory papers, implications for comets and solar system origins, as well as results from ground based observations of the Rosetta target comet 67P/Churyumov-Gerasimenko."
Rosetta fuels debate on origin of Earth’s oceans / Rosetta / Space Science / Our Activities / ESA
Comet 67P has about 3 times as much deuterium (H-2) as the Earth does, and other comets are also enriched, typically by a factor of 2 or 3. Asteroids, however, have amounts of deuterium close to the Earth's, though some of them are enriched up to a factor of 2. Uranus and Neptune, however, have only 1/3 as much, and the Sun, Jupiter, and Saturn only 1/9 as much.
This is likely the result of isotope fractionation in the condensation of water from the protosolar nebula. Heavier isotopes will condense more readily than lighter ones. Heavy water, (H-2)2O, boils at 101.4 C as compared to ordinary water, (H-1)2O, at 100 C. A good check may come from oxygen isotopes, since they also will likely be fractionated. However, oxygen is a major part of rocky materials, which are mostly various metal oxides and metal silicates and silica. That will complicate the history of Solar-System oxygen relative to hydrogen.
Fine structure in the comet's jets.
http://blogs.esa.int/rosetta/2015/01/16/fine-structure-in-the-comets-jets/
Greyscale OSIRIS image of comet 67P/Churyumov-Gerasimenko's bilobed nucleus, with bright sunlit surfaces and dark shadowed flanks, emitting multiple jets of gas and dust into the dark background.
OSIRIS wide-angle camera image acquired on 22 November 2014 from a distance of 30 km from Comet 67P/C-G. The image resolution is 2.8 m/pixel. The vertical line in the bottom right of the image, which seems to separate two regions of the coma with slightly different brightness, is the shadow of the nucleus cast onto the coma.
Credits: ESA/Rosetta/MPS for OSIRIS Team MPS/UPD/LAM/IAA/SSO/INTA/UPM/DASP/IDA
Apparently the ESA is aware that I'm antsy about the Dawn/Ceres probe, so they provided me with some alternative entertainment today:
http://sci.esa.int/where_is_rosetta/
An interactive application which tracks the Rosetta mission from March 3, 2004 to December 31, 2016.
Hints for anyone like me, who never reads the instructions:
left mouse button: rotate
right mouse button: translate
mouse scroll wheel: zoom
When in play mode, the months take less than a second to fly by. So if you get near an interesting event, push pause, and use the "right" and "left" arrow keys. They will change the date by one day.​
I was so enveloped in the animation this morning, that it was almost like being in a movie.
At one point, I screamed; "Look out! You're going to hit Jupiter!"
Diagram of a planetary orbit scene: a small glowing sun at centre with red ring-like orbits, a tan gas giant planet with a ringed orbital path below it, and faint background stars.
January 30, 2008
The comet and Jupiter, from the wrong angle.​
But then I paused the animation, rotated it a bit, and calmed down. :redface:
Links to newly published reports:
http://www.sciencemag.org/site/special/rosetta/
Research Article
On the nucleus structure and activity of comet 67P/Churyumov-Gerasimenko
H. Sierks et al.
A comet with an unusual shape has an array of surface features and high porosity, with early outgassing between its two lobes.
Research Article
The morphological diversity of comet 67P/Churyumov-Gerasimenko
N. Thomas et al.
Images with better than 1-meter-per-pixel resolution shows a comet’s morphology with evidence for complex active processes.
Research Article
Dust measurements in the coma of comet 67P/Churyumov-Gerasimenko inbound to the Sun
A. Rotundi et al.
Observations of the dust outflow show bound and unbound grains and imply a comparatively high dust-to-gas ratio of 4.
Report
67P/Churyumov-Gerasimenko, a Jupiter family comet with a high D/H ratio
K. Altwegg et al.
In situ mass spectrometry reveals a deuterium-to-hydrogen ratio three times that of Earth, which is suggestive of diverse origins for comets in this class.
Report
The organic-rich surface of comet 67P/Churyumov-Gerasimenko as seen by VIRTIS/Rosetta
F. Capaccioni et al.
The reflectance behavior of an illuminated comet is consistent with the presence of nonvolatile organics and sparse water ice.
Report
Time variability and heterogeneity in the coma of 67P/Churyumov-Gerasimenko
M. Hässig et al.
Mass spectrometry performed in situ shows a highly heterogeneous coma with large diurnal and possibly seasonal variations.
Report
Birth of a comet magnetosphere: A spring of water ions
H. Nilsson et al.
The interaction of the solar wind and a comet atmosphere is characterized through detection of the energetic ion environment.
Report
Subsurface properties and early activity of comet 67P/Churyumov-Gerasimenko
S. Gulkis et al.
Measurements at a comet yield water production rates and an assessment of low thermal inertia.
Interesting snippets from a NY Times article on Rosetta.
http://www.nytimes.com/2015/01/23/s...-a-comet-even-with-a-wayward-lander.html?_r=0
Close-up photo of the rugged neck region of comet 67P, showing a steep dark cliff ridge, a pale dusty slope strewn with boulders, and rocky debris in the foreground against a black sky.
A close-up of the "neck region" of the rubber-duck-shaped comet. Credit Eureopean Space Agency
The high-resolution camera has taken photographs with a resolution as fine as two and a half feet per pixel. The comet, just two and a half miles wide with a two-lobe shape that resembles a rubber duck toy, has a remarkably wide variety of terrain. That includes smooth dust-covered regions, fields of boulders, steep cliffs and large depressions that may have been blown out by underground melting of carbon dioxide. The variety is surprising because many think the comet is, by and large, made of the same material throughout. Scientists are not sure if the shape comes from two smaller comets that bumped and stuck together or one large comet that eroded in an unusual manner.
On the surface of Comet 67P, there are even what look like ripples of sand dunes like those seen on Earth and Mars. That appears befuddling, as a comet has no atmosphere — and so no wind — and only a wisp of gravity.
“You have to ask yourself, is that possible?” said Nicolas Thomas, a professor of experimental physics at the University of Bern in Switzerland and lead author of one of the papers. Dr. Thomas said that back-of-the-envelope calculations indicated that it might be plausible, with the jets of gas acting as wind and the particles held together through intermolecular attraction known as the van der Waals force instead of gravity. “You can convince yourself you can make them move,” Dr. Thomas said. “It’s plausible, at least at the moment.”
Close-up grayscale photo of rough, boulder-strewn terrain on a comet surface with dark sky at upper right and a 70 m scale bar in the lower left corner.
A large fracture running across the comet. Credit Eureopean Space Agency
In another region, along the comet’s “neck,” is a cliff about 3,000 feet high with fractures hundreds of feet long. The scientists cannot agree on what they are seeing, whether the lines reflect layering in the material making up the comet or cracks caused by the heating and cooling of the material as it passes in and out of sunshine.
In the smooth regions, there are circular structures. “Which look very, very bizarre,” Dr. Thomas said. “To be frank, we don’t know how those things were created. We have no clue.”
Two grayscale side-by-side views of a rocky surface on Comet 67P/Churyumov-Gerasimenko; the right panel has enhanced contrast, showing a dark pit with fine structures in its shadow.
http://rosetta.jpl.nasa.gov/sites/default/files/gallery_image/Active_pit.jpg
Active Pit
Active pit detected in Seth region of Comet 67P/Churyumov–Gerasimenko. This is an OSIRIS narrow-angle camera image acquired on 28 August 2014 from a distance of 60 km. The image resolution is 1 m/pixel. Enhancing the contrast (right) reveals fine structures in the shadow of the pit, interpreted as jet-like features rising from the pit.
The images are also available separately:
Left hand image
Right hand image
Credit: ESA/Rosetta/MPS for OSIRIS Team MPS/UPD/LAM/IAA/SSO/INTA/UPM/DASP/IDA
Download Active_pit.jpg (12.59 MB)
Active Pit
BBC reports on Goosebumps and Dinosaur Eggs.
http://www.bbc.com/news/science-environment-30931445
Close-up grayscale image of comet 67P's surface showing a dark pit with a rough, bumpy texture; scale bar reads 40m.
A fascinating texture: Comet 67P's "goosebumps" have a preferred scale of about 3m
The data being gathered by the European Space Agency probe is going to keep scientists busy for years, but it is clear already that many of the old ideas about how comets are put together and how they behave will have to change.
It is obvious now that this comet is not a large lump of ice with some dust mixed in. Rather, it has a much more complex construction, incorporating significantly more dust and many rocky components. This is very evident from the ratio of dust to gas being ejected by the comet (four to one), and all those craggy cliff features where stiff, consolidated materials seem to dominate.
"We used to think of comets as 'dirty snowballs'; we now think 'icy dirt-ball' is a much better description," said Simon Green from the UK's Open University. "That's the way 67P looks - a solid object with ice vaporising from somewhere below the surface."
Thanks, everyone, for the links and pics. When I first read that part of the reason for the bounce was that the surface is so much harder than was expected, I knew this was going to be one of the big areas of research. In some ways this information is so fundamental that it is even more exciting than some of the superb data coming off Mars. Once we wrap our heads around how such formations are possible (can Van derWalls actually be this powerful in such conditions is just one example) then what follows is "How could we be so wrong?" in our previous estimates and expectations.
Man! This is exciting stuff!
It's party time for Rosetta and 67P. See the gorgeous photos of cometary jets, glows, streaks and blobs around the active nucleus.
http://www.universetoday.com/119296/dust-whirls-swirls-and-twirls-at-rosettas-comet/
Four grayscale images of comet 67P/Churyumov-Gerasimenko, each showing a bilobed nucleus with rough, bright surfaces against a black background and faint dust jets streaming out from it.
Montage of four single-frame images of Comet 67P/C-G taken by Rosetta’s Navigation Camera (NAVCAM) at the end of February 2015. The images were taken on 25 February (top left), 26 February (top right) and on two occasions on 27 February (bottom left and right). Exposure times are 2 seconds each and the images have been processed to bring out the details of the comet’s many jets. Credits: ESA/Rosetta/NAVCAM – CC BY-SA IGO 3.0
Grayscale image of comet 67P/Churyumov-Gerasimenko, an irregular, rough-textured nucleus with a dark cavity, with faint dust and gas jets fanning out from its top against a black background.
This photo taken on Feb. 27 shows the comet with peacock-like display of dusty jets. Below center is a streak that may be a dust particle that traveled during the exposure. Other small white spots are also likely dust or bits of comet that have broken off. Credits: ESA/Rosetta/NAVCAM – CC BY-SA IGO 3.0
All were taken between February 25-27 at distances around 50-62 miles (80 to 100 km) from the center of Comet 67P/Churyumov-Gerasimenko. Looking more closely, the comet nucleus appears to be “glowing” with a thin layer of dust and gas suspended above the surface. In the lower left Feb. 27 image, a prominent streak is visible. While this might be a cosmic ray zap, its texture hints that it could also be a dust particle captured during the time exposure. Because it moved a significant distance across the frame, the possible comet chunk may be relatively close to the spacecraft . Just a hunch.
Greyscale image of comet 67P/Churyumov-Gerasimenko taken by Rosetta's navigation camera, showing a two-lobed nucleus with a rough, cratered surface and faint dust jets streaming from its upper left.
Particularly striking and collimated jets emerge from the comet’s shadowed Hathor region between the two lobes. Credit: ESA/Rosetta/NAVCAM – CC BY-SA IGO 3.0
OMG!
Yippie!
Rosetta's lander Philae is out of hibernation!
The signals were received at ESA's European Space Operations Centre in Darmstadt at 22:28 CEST on 13 June. More than 300 data packets have been analysed by the teams at the Lander Control Center at the German Aerospace Center (DLR).
"Philae is doing very well: It has an operating temperature of -35ºC and has 24 Watts available," explains DLR Philae Project Manager Dr. Stephan Ulamec. "The lander is ready for operations."
For 85 seconds Philae "spoke" with its team on ground, via Rosetta, in the first contact since going into hibernation in November.
Drakkith said:
From the article: Philae shut down on 15 November 2015 at 1:15 CET after being in operation on the comet for about 60 hours.
My god... NASA invented time travel and didn't tell anyone!
Ah! Hahahaha!
They must have hired Kip Thorne.
:biggrin:
OmCheeto said:
Ah! Hahahaha!
:biggrin:
"C'mon TARS!"
*Epic music plays*
"C'mon TARS!"
Best docking scene ever!
Come on you lot - this is Europe not USA! ESA invented time travel - well we have Dr Who to thank for that!:-p
Huh... no wonder the spacecraft looked vaguely like a phone booth...
LOL @ Drakkith - as soon as I read your phone booth comment I swear I could hear a synth cranking up crunchy rhythms and ooo-Woooo-oooos. :)
"Our observations show that the distribution of water in the coma is highly inhomogeneous," explains Nicolas Biver, CNRS researcher at LESIA-Observatoire de Paris in Meudon, France, and lead author of the study.
The column density of water around comet 67P/C-G, measured by MIRO. From N. Biver et al. (2015)
"We found the highest density of water just above the neck, close to the north pole of the comet's rotation axis: in this narrow region, the column density of water is up to two orders of magnitude higher than elsewhere in the coma," adds Dr Biver.
http://sci.esa.int/rosetta/56065-miro-maps-water-in-comets-coma/
Colour map titled H2O column density showing water column density across the coma of comet 67P/C-G in km units on X and Y axes, with a log(cm-2) colour scale from 13 to 15, and black contour lines overlaid.
Date: 19 June 2015
Satellite: Rosetta
The column density of water around Comet 67P/C-G as measured by the MIRO instrument on Rosetta.
Last Update: 19 June 2015
http://sci.esa.int/rosetta/56070-the-column-density-of-water-around-comet-67p/
Greyscale photo of comet 67P/Churyumov-Gerasimenko's rugged, boulder-strewn surface against black space, with faint jets of dust streaming out from the right edge.
A composite image of four NAV/CAM images taken 19 miles (31 kilometers) from the center of comet 67P/Churyumov-Gerasimenko. A new study has revealed that electrons from the comet, not photons from the sun, are responsible for the breakup of water and carbon dioxide molecules.
Credit: ESA/Rosetta/NAVCAMdiscovery
, which was made using NASA's Alice instrument aboard the European Space Agency's Rosetta spacecraft , was surprising to scientists, who had previously thought that light particles, or photons, from the sun caused these eruptions.
Electrons cause the rapid breakup of water and carbon dioxide molecules erupting from the surface of comet 67P/Churyumov-Gerasimenko, new findings reveal.
"The discovery we're reporting is quite unexpected," Alice instrument principal investigator Alan Stern, of the Southwest Research Institute in Colorado, said in a statement. "It shows us the value of going to comets to observe them up close, since this discovery simply could not have been made from Earth or Earth orbit with any existing or planned observatory, and it is fundamentally transforming our knowledge
of comets."
http://www.space.com/29672-rosetta-comet-eruptions-surprising-discovery.html?utm_source=feedburner&utm_medium=feed&utm_campaign=Feed:+spaceheadlines+(SPACE.com+Headline+Feed)
Some new news:
Philae lander delivers 'ground truth' by touching and analyzing material on a comet's surface [ITV]
30 July 2015 at 7:00pm
By firing radio waves through the comet, from Philae to the orbiting Rosetta spacecraft , scientists also know that around 75-85% of comet 67P is empty space.
That isn't in the form of caves but just the space between the individual grains of dust and ice in the body. Whatever 67P is made from, it very loosely packed.
So, comets are like cotton candy? :biggrin:
http://blogs.esa.int/rosetta/2015/08/11/comets-firework-display-ahead-of-perihelion/
Three black-and-white OSIRIS camera frames of rocky terrain on Comet 67P with a gas and dust jet rising from the left-hand edge; the jet is absent in the left frame, bright and streaming diagonally in the middle frame, and only faintly visible in the right frame.
A short-lived outburst from Comet 67P/Churyumov–Gerasimenko was captured by Rosetta’s OSIRIS narrow-angle camera on 29 July 2015. The image at left was taken at 13:06 GMT and does not show any visible signs of the jet. It is very strong in the middle image captured at 13:24 GMT. Residual traces of activity are only very faintly visible in the final image taken at 13:42 GMT. Credits: ESA/Rosetta/MPS for OSIRIS Team MPS/UPD/LAM/IAA/SSO/INTA/UPM/DASP/IDA
Line graph titled RPC-MAC measurements during outburst, plotting magnetic field strength B_abs (nT) from 0 to 70 against time (UT) on 29 July 2015 from 12:45 to 13:45; a shaded band marks a dip to near 3 nT around 13:20 to 13:28.
The decrease in magnetic field strength measured by Rosetta’s RPC-MAG instrument during the outburst event on 29 July 2015. This is the first time a ‘diamagnetic cavity’ has been detected at Comet 67P/Churyumov–Gerasimenko and is thought to be caused by an outburst of gas temporarily increasing the gas flux in the comet’s coma, and pushing the pressure-balance boundary between it and incoming solar wind farther from the nucleus than expected under ‘normal’ levels of activity.
Credits: ESA/Rosetta/RPC/IGEP/IC
Bar chart titled ROSINA measurements of comet gas following outburst, showing relative abundances of CH4, NH3, H2O, C2H2, HCN, CO, C2H6, CH3OH, H2S, CO2, OCS, SO2 and CS2 after an outburst, with a horizontal line marking the water vapour level; H2S is highest at about 6.9.
During an outburst of gas and dust from Comet 67P/Churyumov–Gerasimenko on 29 July 2015, Rosetta’s ROSINA instrument detected a change in the composition of gases compared with previous days.
The graph shows the relative abundances of various gases after the outburst, compared with measurements two days earlier (water vapour is indicated by the black line).
Credits: ESA/Rosetta/ROSINA/UBern/ BIRA/LATMOS/LMM/IRAP/MPS/SwRI/TUB/UMich
Soon afterwards, the comet pressure sensor of ROSINA detected clear indications of changes in the structure of the coma, while its mass spectrometer recorded changes in the composition of outpouring gases.
For example, compared to measurements made two days earlier, the amount of carbon dioxide increased by a factor of two, methane by four, and hydrogen sulphide by seven, while the amount of water stayed almost constant.
This comet strikes me a fodder for either kooks or sci-fi bufs:
1. "75-85% of comet 67P is empty space." [ref]
It's hollow! What could be inside it?​
(it's not really hollow)
2. "...But today we can report that the following have also been detected: Formaldehyde..." [ref]
Formaldehyde? Isn't that what they embalm people with? It's a ship full of dead aliens!​
(Actually, lots of compounds have been found on Comet 67P/C-G. Formaldehyde is just a water molecule that's been dissected, and someone put a carbon atom in the middle. I just found this out, btw. I'm dreadfully bad at chemistry.)
3. "ESA Rosetta Mission ‏@ESA_Rosetta 2h2 hours ago
"T-12 hours to #Perihelion2015! Closest approach to #Sun occurs at 02:03UT on 13 Aug #FinalCountdown"
Something is going to happen! Perihelion is a big word!​
(Ok...)
4.
Black and white photo of a rugged, rocky cometary surface with jagged cliffs in the foreground against a black sky, with a faint glow of dust rising above the edge.
The alien spacecraft fired an attitude adjusting jet! We knew something was going to happen! And look at Dotini's magnetic field graph that coincides with the jet. Obviously, the aliens withdrew the magnetic energy of the comet to power the jet. ​
(I actually have no idea what is going on with this. But it inspired my post. This is really weird. )
5. "Do you remember where you were on November 12, 2014 when Philae landed on comet 67P/Churyumov-Gerasimenko?
For three nerve-wracking days, the world's attention was focused on the tiny spacecraft , as it bounced its way across the surface of the comet, 300 million miles from Earth.
Though it landed in the wrong place...
Wrong place? Pfft. It's exactly where the alien spacecraft wanted it, so that could suck the energy from its solar panels. Have we seen any selfies from Philae lately? No!​
Ok. #5 was my lame attempt at humour. My apologies. :redface:
But science should be fun. :oldbiggrin:[URL='https://twitter.com/ESA_Rosetta']ESA Rosetta Mission ‏@ESA_Rosetta 9 hours ago[/URL]
<1 day to #67P #perihelion2015 & 185,997,031km to the Sun today! Hope @Philae2014 remembered to pack his sunglasses!
Cartoon illustration of a white box-shaped spacecraft with blue sunglasses and a smile, solar panels extending left and right, against a starry blue background.
Someone could make a great tin-hat salesman!
Well the jets are towards the sun, right? Perhaps the aliens are inside the sun transmitting the "start destruct sequence" signal which has to penetrate the exterior "decoy" layers. So now you know. :wink:
shhhhhhh! I've already alerted admin that I should not be a member of this forum. I think he thinks I was kidding...
I don't know!
That could be.
But I just have so much fun thinking about all this stuff.
I consider the July 29th jet to be a case of fact being stranger than fiction.
Most likely, it is because I have nearly zero knowledge of chemistry.
Why was there a 7 fold increase in hydrogen sulphide? Could this jet have been caused by a thermally induced chemical reaction? Or was that just a freakishly deep pit, with stratified compounds?
I really have no idea.
But PF is filled with freakishly smart people, and I know they will answer, the silliest of questions. :smile:
And hopefully not ban me, for being an idiot. :redface:
:bow:
Smart, yes, but also cautious and prudent. In the midst of rapid-fire discoveries, nobody wants to be caught saying anything that's seen to be wrong the very next week.
Seriously glad this is fun for you. Me too. :woot:
Looking at the shadows in the pictures I don't think it could be towards the sun. I was thinking about a comets "tail" being towards or away from the sun but now I forget which way it is. I have to say away since I think the tail tapers out at nearly the angle that a shadow would be cast. Sorry for not just googling it but I need to exercise my memory.
Sad. A thousand silly ideas might yield one good one.
It used to be called "brainstorming", in the olden days.
Do people ever do that anymore? Or have egos gotten so huge, that even the thought of positing an incorrect notion, sends people scurrying, like frightened mice?
:smile:
