Rotating an ellipse to create a spheroid?
2 replies · 3K views · last reply
gary0000
This problem began with solving for an 2D ellipse whose axis aligned with the y-axis and the line x=-z. Then the ellipse needs to be translated, rotated, and then revolved to form a spheroid. I've already found the rotated and translated ellipse.
Rotate the following ellipse about its major axis to obtain a prolate spheroid:
(195.010)^2*((x-72.850)*cos(1.423)+(y-490.030)*sin(1.423))^2+(532.419)^2*((x-72.850)*sin(1.423)-(y-490.030)*cos(1.423))^2-(532.419)^2*(195.010)^2=0
[Each x-value corresponds to a negative z-value of equal magnitude as well, since this ellipse is in the plane formed by line x=-z and the y-axis, not the xy plane.]
General equation of an ellipse: x^2/a^2+y^2/b^2=1
(in my case b>a)
Equation of an ellipse with a rotated axis and translated center:
((x−h)cos(A)+(y−k)sin(A))^2/(a^2)+((x−h)sin(A)−(y−k)cos(A))^2/(b^2)=1
General equation of a prolate spheroid: (x^2+y^2)/a^2+z^2/c^2=1, where c > a
I was able to find the equation of an ellipse where its major axis is shifted and rotated off of the x,y, or z axis. However, I could not find anywhere an equation for a spheroid that does not have its axis or revolution along the x,y, or z axis. How might I go about deriving such an equation?For this spheroid specifically I have found that:
-It's axis of revolution passes through the origin
-Its center its located at the point (72.846,490.034,-72.846)
-It's radius is 195.010 units long
-Its semi-major axis is 532.419 units long
(I attached an image of a plot of the ellipse that needs to be revolved with its axis of revolution represented by a yellow line)
  • Plot of a tilted ellipse in blue, with a red lower arc and a yellow straight line from the origin rising steeply to the upper right, axes labelled from -150 to 300 horizontally and -100 to 1.1·10³ vertically.
Let's say your ellipse has axes of length ##A## and ##B##, and center ##(h,k)##, and is rotated by angle ##\theta##. This is represented by the equation $$\frac{((x-h)\cos(\theta)+(y-k)\sin(\theta))^2}{A^2}+ \frac{((x-h)\sin(\theta)-(y-k)\cos(\theta))^2}{B^2} =1.$$ If ##A>B## then I suspect the equation you're looking for is
$$\frac{((x-h)\cos(\theta)+(y-k)\sin(\theta))^2}{A^2}+ \frac{((x-h)\sin(\theta)-(y-k)\cos(\theta))^2}{B^2} + \frac{z^2}{B^2}=1,$$
simply tacking on a ##z^2/B^2## term. The denominator is ##B^2## because, since we're revolving around the semi-major axis, the new axis must have the same length as the semi-minor axis. There's none of the extra stuff in the numerator either because those only deal with translations and rotations in the ##xy##-plane. Using a 3D-grapher, it'll look something like this:
3D graph of a red ellipsoid of revolution sitting above a grey plane, with red x-axis, green y-axis and blue z-axis marked with tick labels from -3 to 5.
(I used ##h=1, k=2, \theta=\pi/6, A=2, B=1##).
  • 3D plot of a red ellipsoid of revolution sitting above a grey plane, with red x-axis, green y-axis and blue z-axis marked from -3 to 5, 4 and -2.
Small plot of a blue ellipse and a red curve on axes, with a yellow line drawn diagonally through the ellipse; axis labels and numbers are too small to read.
I haven't checked your numbers, but unless I misunderstand, your picture can't be correct. A prolate spheroid must be an ellipse rotated about its major axis. Your yellow line apparently doesn't align with the major axis.
