What is the mass of the cylinder?
The discussion focuses on calculating the mass of a solid cylinder using a massless string and a block of mass 2.0 kg. The block falls 82 cm in 2.0 seconds, leading to an acceleration of 0.41 m/s². By applying the equations of motion and torque, the user deduces that the mass of the cylinder is 91.6 kg, as the radius cancels out in the torque equation. The user seeks confirmation of their solution and additional geometric information for clarity.
  • Understanding of Newton's second law of motion
  • Familiarity with rotational dynamics and torque
  • Knowledge of kinematic equations
  • Ability to interpret free-body diagrams
  • Study the relationship between linear and angular acceleration in rotational systems
  • Learn about the moment of inertia for different shapes, including solid cylinders
  • Explore the concept of tension in strings and its effect on rotational motion
  • Investigate the application of free-body diagrams in complex mechanical systems
Students in physics, particularly those studying mechanics, as well as educators and anyone involved in solving problems related to rotational motion and dynamics.
magnummd
Problem: A massless string is wrapped around a solid cylinder as shown in the diagram at the right. A block of mass m = 2.0 kg hangs from the string. When released, the block falls a distance of 82 cm in 2.0 s. Starting with a free-body diagram, calculate the mass of the cylinder.
d = volt + 0.5at^2
Tension = ma - mg
Torque = (I)(alpha) = F(r)
Conceptually, I figure I need to find the force being exerted on the wheel, and the acceleration. That will leave nothing but the mass to be determined. But the fact that it's rotational, throws a wrench into it, especially since no radius is provided.
using d = volt + 0.5at^2 we get a = 0.41 m/s^2 for the block.
Tension is therefore, 18.78 N in the opposite direction of the block's movement and is the force being exerted on the wheel (I think).
Torque = 18.78(r) = 0.5Mr^2(a/r)
If my approach is right, I need M, but r is in the way. What to do?
Wait a minute... the radii all cancel... therefore M = 37.56/0.41 = 91.6 kg
Did I figure it out, or did I just dig myself into a deeper hole? Help please!
Could you give more information about the geometry?
I don't really know where I could attach a photo of it, but it essentially looks like a string hanging off a pulley with a mass on the end.
Any suggestions on how I can show it to you?
When you make a new reply below "submit reply" look for a button called "Manage Attachments".
Sweet thanks! Here it is:
I'm new to this forum but just a general hint i post my pictures on photobucket.com and then just click the image button where i want it in the post and paste in the link ...
Anything guys (or ladies)?
The attachment's been approved. So does anyone have any ideas?
Your solution looks good to me.
Alright then! Thanks a lot!
  • · Replies 21 ·
  • · Replies 29 ·
  • · Replies 45 ·
  • · Replies 19 ·
