Rotational motion roller coaster problem
6 replies · 5K views · last reply
joe426
Physics problem diagram of a roller-coaster track with two vertical circular loops of radii r1 and r2, point A at the bottom of the first loop and point B at the top of the second, with a car at the top of the lift hill.
ƩF = ma = (mv2) / r
For part A:
Fn - Fg = (mv2) / r
Fn = ((mv2) / r ) + mg
Fn = (500x20^2) / 10 + 500x9.8
Fn = 24900
This seems too high to be true. But I'm unsure of what I did wrong. I know the normal force is the force of which the track is acting on the car.
For part B:
I think it is just 20m/s but I'm not sure. I know an object traveling in a circle has the most speed when it's at the bottom of the circle.
Thanks for the help in advance!
Part A looks correct.
For part B, set up equations similar to part A and think about what happens to the value of Fn when the vehicle leaves the track.
Hmm...
I think Fn would equal 0 when the vehicle leaves the track. So I use the same equation as part A except I set Fn to 0 and solve for v?
joe426 said:
Hmm...
Yes Fn will be zero. Good. But if you use the same equation you will end up taking the square root of a negative number (oops). Set up a correct similar equation using a new free body diagram for point B
Fg - Fn = (mv2) / r
(mgr / m)1/2 = v
(500x9.8x15 / 500)1/2 = 12.1
V = 12.1
Good! (minus 1 point for not including units :devil:)
Haha thank you so much! I got the units on my paper :P
