Rotational Motion: Who Reaches Bottom First?
In summary, the hoop with the spokes has more total energy and will reach the bottom of the ramp first. This is due to the greater mass of the hoop and its increased moment of inertia.
justagirl
29
Two hoops of identical radii roll without slipping down identical inclined planes under the influence of gravity. Hoop 1 is identical to Hoop 2 except for some massive spokes which are fixed to the rim.
If the two hoops are released at the same time from the same height, which hoop makes it to the bottom of the ramp first?
Thanks!
Each hoop starts with the same amount of energy at the top of the ramp.
Which one has more translational kinetic energy at the bottom? Or, perhaps more importantly, which one has more rotational kinetic energy at the bottom, and how would this affect the translational KE?
What does this result mean for the time it takes to get to the bottom?
--J
re;
The part of I'm confused on is this:
The wheel with the spokes has more mass, which increases inertia and decreases speed. But it also has more mass concentrated around the radius, which increases speed...
What does this mean?
Consider the moment of inertia as a whole. Also remember that angular velocity (and hence angular KE) is proportional to linear velocity, i.e. the faster the wheel is moving down the ramp, the faster it's rolling.
--J
I'm a lil confused:
so by conservation of energy I have:
mgh = 1/2mv^2 + 1/2Iw^2
mgh = 1/2mv^2 + 1/2I(v^2/r^2)
V^2(1/2m + 1/2(I/R^2) = mgh
v^2 = mgh / (1/2m + 1/2(I/R^2))
For spoke one, the mass is greater, so speed decreases...
But wouldn't I be smaller? Wouldn't that increase the speed?
You've caught the important part of the problem.
If the total mass of the two hoops are equal, the wheel with the spokes has more mass towards the center and a smaller moment of inertia. It accelerates faster. (I=mr^2)
If the two hoops are identical (i.e. - they have the same amount of mass out on the rim) except one hoop has some additional mass added to it in the form of spokes, the one with the spokes has the larger moment of inertia. Technically, the moment of inertia is the sum of the moment of inertia of each piece of the hoop. So, adding mass, regardless of its placement, is adding more inertia.
In other words, read the question carefully and make sure which condition the question is talking about.
would the smaller inertia hoop be going faster or does it not matter? I think we did this experiment where we found acceleration to be g sin theta / (1 + c), where c was the constant of inertia. (i.e., 1/2 for a cylinder and 1 for a hoop).
help! can someone please answer/
The hoop with the spokes is both heavier and has a larger moment of inertia.
Suppose both hoops are going down the ramp with velocity v. Compare their total kinetic energies.
E = mv^2/2 + Iw^2/2
Note that both m and I are larger for the hoop with the spokes, so v and w must be smaller in order to achieve the same total energy.
--J
1. What is rotational motion?
Rotational motion is the movement of an object around an axis or center point. It can be seen in objects such as spinning tops or planets orbiting around a star.
2. What factors affect the speed of rotational motion?
The speed of rotational motion can be affected by the radius of the rotating object, the force applied to it, and the mass of the object. The shape and surface of the object can also play a role.
3. Why do objects of different masses reach the bottom at the same time in rotational motion?
In rotational motion, the force acting on an object is dependent on its mass and the radius of rotation. Therefore, objects with different masses but the same radius will experience the same force, resulting in them reaching the bottom at the same time.
4. How does air resistance affect rotational motion?
Air resistance can slow down the speed of rotational motion by creating friction between the rotating object and the surrounding air. This can also cause objects of different masses to reach the bottom at different times.
5. What is the difference between linear and rotational motion?
Linear motion is the movement of an object in a straight line, while rotational motion is the movement of an object around an axis. In linear motion, the distance and speed are important, while in rotational motion, the radius and angular speed are more relevant.
15K
