Why Divide by (p + 2) in Rudin's Proof on Page 2?
  • Thread starter Thread starter sponsoredwalk
    Proof
The discussion centers on the mathematical proof presented in Walter Rudin's book, specifically the division by (p + 2) in the equation q = p - (p² - 2)/(p + 2). This division is crucial for demonstrating that there is no rational number p such that p² = 2. The participants conclude that dividing by (p + 2) helps maintain the inequality and ensures that q remains a valid candidate in the set A, which contains rational numbers less than √2. The necessity of this division is emphasized as a means to avoid logical dead ends in the proof.
  • Understanding of rational numbers and their properties
  • Familiarity with inequalities and their manipulation
  • Basic knowledge of limits and sequences in real analysis
  • Experience with mathematical proofs, particularly in number theory
  • Study the concept of limits in real analysis to understand convergence
  • Explore the implications of the Archimedean property in rational numbers
  • Learn about the completeness property of real numbers
  • Review exercises 16 and 17 in Rudin's "Principles of Mathematical Analysis" for deeper insights
Mathematics students, educators, and anyone interested in understanding proofs related to irrational numbers and the properties of rational numbers in real analysis.
sponsoredwalk
I wrote a big question as regards this question but pretty much made
sense of it all apart from one bit, why divide by (p + 2) in
q \ = \ p \ - \ \frac{p^2 \ - \ 2}{p \ + \ 2}
in the proof on page 2 of Rudin?
(Check it on the https://www.amazon.com/dp/007054235X/?tag=pfamazon01-20 using amazon's search feature)[/size].
The goal is to show that there is no rational number satisfying p² = 2. I'm
fine with the (m/n)² = 2 part, i.e. that a number is even if it's divisible by 2
& odd if it's divisible by 2 leaving 1 as a remainder but when he "examines
this situation a little more closely" I just don't see where (p + 2) comes
from, why not just Δp or something, why so specific? In fact, why
even bother dividing at all?
A := {p ∈ Q| p² < 2}
B := {p ∈ Q| p² > 2}
To show that A has no largest element there should be a q in A such that
p < q he invents this equality for q.
Now, the only logic I can see here is that if p² < 2 & we divide by (p + 2)
(for some reason):
(p^2 \ &lt; \ 2) \ \Rightarrow \ ( \frac{1}{p \ + \ 2} ) \cdot \ (p^2) \ &lt; \ ( \frac{1}{p \ + \ 2} ) \cdot \ (2)
\Rightarrow \ \frac{2}{p \ + \ 2} \ &lt; \ \frac{p^2}{p \ + \ 2}
\Rightarrow \ ( \frac{p^2}{p \ + \ 2}) \ - \ \frac{2}{p \ + \ 2} \ &lt; \ 0
\Rightarrow \ ( \frac{p^2 \ - \ 2}{p \ + \ 2})
I just don't see why dividing matters. Would it not be better to just
not divide at all, wouldn't there still be a gap between p & q due to
the < sign?
If p² < 2 then (p² - 2) < 0 & q = p - (p² - 2) so q = 2 + (p - p²)
Then q - 2 = (p - p²) & that's really unhelpful.
No, it would not be better I guess :redface: But you see what I mean, I'd just like to
know why he divides. I can understand that he does it that way to strictly avoid the
dead end I've come up with when doing no division but I'm hoping there's some deeper
meaning as opposed to just an example of crazy genius at play :-p Any thoughts?
What Rudin did here was a slight variation of exercises 16 and 17 in chapter 3, page 81 of the same book. Anyways if you just want a quick answer, then the (p+2) denominator is somewhat necessary. For more abstraction, that 2 can be any number higher than √2 for the equation to work. You should be able to figure out why by changing the 2 to √2 in the bottom and seeing what happens.
  • · Replies 24 ·
