Rudin POMA: chapter 4 problem 14
  • Thread starter Thread starter anon3335
    Real analysis
anon3335
Question: Let ##I = [0,1]##. Suppose ##f## is a continuous mapping of ##I## into ##I##. Prove that ##f(x) = x## for at least one ##x∈I##.
Define first(##[A,B]##) = ##A## and second(##[A,B]##) = ##B## where ##[A,B]## is an interval in ##R##.
Proof: let ##M = sup\ f(I)## and ##m = inf\ f(I)##. Assume that ##M ≠ m## and that ##f(x) ≠ x## for all ##x∈ I##.Then ##f## is strictly monotonic and so let ##L_1## = ##[f(m),f(M)]## and define ##L_n ##=## [f(first(L_{n-1}), f(second(L_{n-1}))]## (##n ≥ 2##). Then V=## \bigcap L_n## is non empty. Now let ##y∈V##. Then there exists ##x_1∈ V## such that ##f(x_1) = y##. Then if ##x_1 ≠y##, we have ##f(x_1) ≠ y##, which is a contradiction and so ##x_1 = y##. But this is contradicting our assumption. For the case where ##M = m## it is trivial as the function would be a constant one.
I don't see how ##M>m## and ##f(x) ≠ x## imply that f(x) is monotonic.
Since then ##f## would be a continuous injective function on ##I## and so it is strictly monotonic.
I agree that a continuous injective function is monotonic, but why is the function injective? How does ##f(x) \neq x## imply this?
Let ##x_1## ≠ ##x_2##. Then one gets ##f(x_1) ≠ f(x_2)## according to our assumption and so ##f## is injective.
Your argument is ##x_1 \neq f(x_1)## and ##x_2 \neq f(x_2)## implies ##f(x_1) \neq f(x_2)##?
Yup.
anon3335 said:
Yup.
So ##f(x_1) \neq x_1 \neq x_2 \neq f(x_2)## implies ##f(x_1) \neq f(x_2)##? But ##\neq## is not transitive
Basically, you're trying to show that every function f that maps the interval [0, 1] into itself must cross through or touch the line y = x at least once. I agree with @tnich that you are asserting that f is injective without showing why this must be true. In fact, for the given conditions, it doesn't have to be true (that f is injective).
In the graph below, f (dark curve) maps [0, 1] into [0, 1]. f is continuous on [0, 1], but neither injective nor surjective.
What could you do with the function ##g(x) \equiv f(x) - x##?
Yes you are right. My argument is flawed in that step, but what if we delete that part from the proof? wouldn't the proof still hold?
Can you make your sequence of intervals converge without it? Could you make your sequence converge even with it? Consider the case ##f(x) = 1-x##.
Ah I see. Yes the argument would not hold. Thanks for your help.
I have solved the problem with this specific way, but I wanted to solve the problem with another approach.
