Rudin POMA: chapter 4 problem 14
  • Thread starter Thread starter anon3335
    Real analysis
The problem involves proving that for a continuous function \( f \) mapping the interval \( I = [0,1] \) into itself, there exists at least one point \( x \in I \) such that \( f(x) = x \). This falls under the subject area of fixed-point theorems in analysis.
  • Participants discuss the implications of the assumptions regarding the supremum and infimum of \( f(I) \) and whether these imply monotonicity. There is a focus on the injectivity of \( f \) and its relationship to the continuity of the function. Questions arise about the validity of certain arguments and the necessity of specific steps in the proof.
The discussion is ongoing, with participants questioning the assumptions made about injectivity and monotonicity. Some have suggested alternative approaches and are exploring the implications of removing certain arguments from the proof. There is recognition of flaws in reasoning, prompting further inquiry into the continuity and behavior of the function.
Participants are navigating the constraints of the problem, particularly regarding the assumptions about the function's behavior and the implications of continuity on the existence of fixed points. There is an acknowledgment that the proof may not hold under certain interpretations of the function's properties.
anon3335
Question: Let ##I = [0,1]##. Suppose ##f## is a continuous mapping of ##I## into ##I##. Prove that ##f(x) = x## for at least one ##x∈I##.
Define first(##[A,B]##) = ##A## and second(##[A,B]##) = ##B## where ##[A,B]## is an interval in ##R##.
Proof: let ##M = sup\ f(I)## and ##m = inf\ f(I)##. Assume that ##M ≠ m## and that ##f(x) ≠ x## for all ##x∈ I##.Then ##f## is strictly monotonic and so let ##L_1## = ##[f(m),f(M)]## and define ##L_n ##=## [f(first(L_{n-1}), f(second(L_{n-1}))]## (##n ≥ 2##). Then V=## \bigcap L_n## is non empty. Now let ##y∈V##. Then there exists ##x_1∈ V## such that ##f(x_1) = y##. Then if ##x_1 ≠y##, we have ##f(x_1) ≠ y##, which is a contradiction and so ##x_1 = y##. But this is contradicting our assumption. For the case where ##M = m## it is trivial as the function would be a constant one.
I don't see how ##M>m## and ##f(x) ≠ x## imply that f(x) is monotonic.
Since then ##f## would be a continuous injective function on ##I## and so it is strictly monotonic.
I agree that a continuous injective function is monotonic, but why is the function injective? How does ##f(x) \neq x## imply this?
Let ##x_1## ≠ ##x_2##. Then one gets ##f(x_1) ≠ f(x_2)## according to our assumption and so ##f## is injective.
Your argument is ##x_1 \neq f(x_1)## and ##x_2 \neq f(x_2)## implies ##f(x_1) \neq f(x_2)##?
Yup.
anon3335 said:
Yup.
So ##f(x_1) \neq x_1 \neq x_2 \neq f(x_2)## implies ##f(x_1) \neq f(x_2)##? But ##\neq## is not transitive
Basically, you're trying to show that every function f that maps the interval [0, 1] into itself must cross through or touch the line y = x at least once. I agree with @tnich that you are asserting that f is injective without showing why this must be true. In fact, for the given conditions, it doesn't have to be true (that f is injective).
In the graph below, f (dark curve) maps [0, 1] into [0, 1]. f is continuous on [0, 1], but neither injective nor surjective.
What could you do with the function ##g(x) \equiv f(x) - x##?
Yes you are right. My argument is flawed in that step, but what if we delete that part from the proof? wouldn't the proof still hold?
Can you make your sequence of intervals converge without it? Could you make your sequence converge even with it? Consider the case ##f(x) = 1-x##.
Ah I see. Yes the argument would not hold. Thanks for your help.
I have solved the problem with this specific way, but I wanted to solve the problem with another approach.
