RuntimeWarning in sinc(x) division by zero with numpy.where
  • Topic: MATLAB
  • Thread starter Thread starter Ascendant0
    Error Graph Plotting
5 replies · 5K views · last reply
Ascendant0
TL;DR
We were given an assignment to produce a plot of the function ## f(x) = sin(x)/x ##, and set it up visually the way he has (including a red dashed line on y = 0). I have completed the code, but I'm getting an error message and not sure why
This is my code:
Python:
import numpy as np
import matplotlib.pyplot as plt
def sinc(x):
    return np.where(x == 0, 1, np.sin(x)/x)
x = np.linspace(0, 25, 500) # mainly for setting the number of values generated
y = sinc(x)
plt.xlim(0, 25) # set range for x axis
plt.ylim(-0.4, 1) # set range for y axis
plt.plot(x, y, color='green', linewidth=1.5, label='sinc(x)')  # sin(x)/x graph
plt.axhline(0, color='red', linewidth=1, linestyle='--', label='y=0') # y=0 graph
plt.xlabel('x')
plt.ylabel('sinc(x)')
# obviously these 2 are for the x and y axes labels
plt.show()
Now, while that is showing my plot correctly just as he had on the example, it is giving me this error message when I run it:
"RuntimeWarning: invalid value encountered in divide return np.where(x == 0, 1, np.sin(x)/x)"
I'm not sure why though, and I don't want to mess it up. Please keep in mind this is my VERY first time EVER using Python (and I don't know MATLAB either), so I compiled that part based off the best way I could figure out to do it. Would there be a better way to code that part, or is there just something slight I need to adjust in it? Again, please keep in mind it is plotting correctly as-is, so I have what I need, I just want to clean up whatever the problem is. Help would be greatly appreciated, as I can't figure it out. Every time I try to adjust it, it ends up not working anymore.
So, I cleaned up my code some. Changed these two lines to this:
"def sinc(x):
return np.sin(x)/x)"
Realized I didn't need that other code. I still get the same error, but I'm thinking now it's due to sin(x)/x being invalid at 0. Just not sure how to get it to overlook that, or if it is just something it will always point out like that?
Ascendant0 said:
TL;DR Summary: We were given an assignment to produce a plot of the function ## f(x) = sin(x)/x ##, and set it up visually the way he has (including a red dashed line on y = 0). I have completed the code, but I'm getting an error message and not sure why
This is my code:
import numpy as np
Code:
def sinc(x):
The problem is that python will evaluate all of the arguments of np.where before passing them to it - including, in the case x == 0, the result of np.sin(0)/0. Thus you need to ensure that np.sin(x)/x is not evaluated for x == 0.
Orodruin said:
Change your definition of sinc to return 1 if the argument is 0.
That by itself doesn't work for vectorised input, which is almost the entire point of NumPy. There is, however, a solution: use numpy.vectorize.
Python:
>>> import numpy as np
>>> def my_sinc(x):
...     if x == 0:
...         return 1.0
...     else:
...         return np.sin(x)/x
>>> my_sinc(np.array([0,1]))
Traceback (most recent call last):
  File "<pyshell#8>", line 1, in <module>
  File "<pyshell#7>", line 2, in my_sinc
    if x == 0:
ValueError: The truth value of an array with more than one element is ambiguous.
Use a.any() or a.all()
>>> np.vectorize(my_sinc)(np.array([0,1]))
array([1.        , 0.84147098])
I should note for completeness that NumPy has its own library function numpy.sinc, defined as [tex] \operatorname{sinc} : x \mapsto \begin{cases} 1 & x = 0, \\ \frac{\sin(\pi x)}{\pi x} & x \neq 0. \end{cases}[/tex]
EDIT: Another option is
Python:
x = np.linspace(0, 25, 5000)
y = np.concatenate([
   np.array([1.0]),
   np.sin(x[1:])/x[1:]],
   axis = 0
Not if you just take the function as written, obviously. There are simple solutions though. Vectorizing should not be necessary.
