Sabine Hossenfelder says time dilation is due to acceleration
The discussion centers around Sabine Hossenfelder's claim that time dilation in the twin's paradox is due to acceleration. Participants explore the validity of this assertion, examining the relationship between time dilation, acceleration, and velocity, as well as the implications of these concepts in the context of relativity.
  • Some participants question Hossenfelder's assertion that "real time dilation" comes from acceleration, arguing that time dilation is fundamentally linked to velocity rather than acceleration.
  • One participant explains that in scenarios where two observers have constant velocities, they experience symmetric time dilation, and breaking this symmetry requires one observer to accelerate.
  • Another participant introduces the distinction between time dilation and differential aging, suggesting that differential aging can occur without acceleration and is more closely related to velocity profiles.
  • Several participants express disagreement with Hossenfelder's statement, asserting that acceleration does not directly cause time dilation and that the effects depend more on velocity and time spent at different velocities.
  • One participant mentions that there are versions of the twin paradox that do not involve acceleration, complicating the assertion that acceleration is the cause of time dilation.
  • Concerns are raised about the oversimplification of complex concepts in popular science explanations, suggesting that such simplifications can lead to misunderstandings.
Participants generally disagree with Hossenfelder's assertion that time dilation is due to acceleration, with multiple competing views on the relationship between acceleration, velocity, and time dilation remaining unresolved.
Participants note that while acceleration is necessary for breaking the symmetry in the twin's paradox, the actual effects of time dilation and differential aging are more directly related to the velocity profiles of the observers involved.
  • #31
Epic Mythology said:
Do you believe that influential and popular public science educators have a duty to speak the truth and be correct?
What are your own thoughts about this? Once again, your thread is derailing into a cascade of questions that you ask - but you always seems to fail to answer the questions that are directed to you.
You can find a nice explanation what time dilation is in this post https://www.physicsforums.com/threa...e-experiences-which-time.1051231/post-6870973
All other "effects" of time discrepancies should imo NOT be called time dilation in order not to be confusing.
  • #32
Sabine Hossenfelder says time dilation is due to acceleration in the twin's paradox. Is this true?
At 12 minutes into this video ,
Hossenfelder states, "This is the real time dilation. It comes from acceleration."
Looking at the equations for time dilation, time dilation comes from velocity, not acceleration.
How can Hossenfelder state, "This is the real time dilation. It comes from acceleration."?
The problem here is being unspecific which acceleration is meant. As I stated in the previous thread about this video:
The confusion starts when accelerating reference frames (which can have clocks going at different rates at different locations) are conflated with the proper acceleration of the clocks themselves (which doesn't affect the clock rate).
Sabine Hossenfelder's statements at timestamp 18:00 are clearly contradicting the clock hypothesis:
https://en.wikipedia.org/wiki/Time_dilation#Clock_hypothesis
  • #33
So are you agreeing with Hossenfelder's statement that "This is the real time dilation. It comes from acceleration." What are the physical equations that show acceleration causes time dilation?
There isn't one in the sense you want. The clock hypothesis states that time dilation only depends on velocity.
It's like calculating dL of a line segment, integrating them to find L between two fixed points a and b, and noticing that L depends on the change of direction of the line segments dL. This change of direction is reflected in the dx and dy parts in every dL.
Similarly, an acceleration changes v(t), and hence the elapsed proper time. But this elapsed proper time does not explicitly depend on the acceleration.
Edit: plus what Dale says in #13.
  • #34
Yes, and the clock hypothesis has been confirmed by observation for amazing accelerations. I don't know, why you make such a fuss about some pop-sci youtube video...
  • Love
  • Haha
  • #35
If I had a coin for each time a pop-sci article or video were... let's say "not accurate" - I would be rich!
  • #36
Ibix said:
Yes. In flat spacetime someone has to accelerate for twins to meet twice, but the effect depends on the velocity and how much time is spent at different velocities, not on acceleration. Working in inertial coordinates, the elapsed time for one twin is ##\int\sqrt{1-v^2(t)/c^2}dt##. Do you see any acceleration term in there?
This is a tricky thing that most relativists get but that to a first approximation, no popular physics writers understand. (Dr. Hossenfelder is a relativist and understands this very well.)
Let's say we have two clocks at a particular moment at rest with respect to each other, but one is accelerating. Thus far there is NO experimental evidence that the clocks' rates are different. For example, one can consider muons (whose lifetime is very short if they're at rest) moving in straight lines at high velocities, and compare them with muons moving in circular storage rings at Fermilab and elsewhere at the same velocity, and they have the same observed lifetime, (given by the usual time dilation formula involving the square root of ##1 - (v/c)^2##) even though the ones moving in circles are experiencing gigantic accelerations and the others are not. So acceleration all by itself does not affect clock rates. (The hypothesis that acceleration by itself does not influence the clock rate is called "the clock hypothesis". There is no theoretical basis for it thus far that I am aware of.) So far, so good.
However, it is known that clocks on an upper level of an apartment building run at a tiny bit faster than those on the ground level; the higher you go, the faster the clock rate. This is not due to the gravity, exactly (the gravitational field is nearly the same), but to the gravitational potential, which is in this case the product of ##g## and the height, ##y##, divided by ##c^2##. (For folks who remember some physics, gravitational potential means "gravitational potential energy per kilogram".) Google "gravitational red shift" for more about this. The equation comparing clock rates is this:
##\Delta t_{\text{higher}} = \Delta t_{\text{lower}}(1 + (gy/c^2))##
If this effect were not taken account of by GPS satellites, your phone apps telling you where you were would be very badly incorrect!
Finally, there is a thing called "the equivalence principle": if an elevator is small enough, you cannot distinguish between the effects of being accelerated up at ##g## meters per second squared or being stationary (or moving with constant velocity) in the earth's gravitational field of ##g## meters per second squared. What this means is that during acceleration, a person with an accelerated clock would measure the rate of an clock at a distance of ##y## meters away as running <i>faster</i> than hers, according to the formula above. That is, the factor of ##(1 - (v/c)^{2})## has to be replaced by ##((1 + gy/c^{2})^2 - (v/c)^2)## in the square root, where $y$ is the distance between the accelerated clock and the unaccelerated clock.
This is the cheap solution to the so-called "twin paradox". Say a traveling twin sets out from earth, goes to a distant star, turns around and comes back. There are three periods of acceleration: near the earth going away, turning around, and near the earth to slow down. During periods of steady motion, both the traveler and the stay at home see each other's clock running slow with respect to each other's (they have to; this is a theory of relativity). During the acceleration near the earth, both twins agree that the stay at home twin's clock runs faster than the traveler's, but not appreciably so, because the distance ##y## is not very big. However, during the turnaround, the traveler thinks the earth based twin's clock runs much faster, due to the large value of ##y##. Detailed calculation shows that this rate is precisely what is needed (with the slight increase near the earth) to reconcile the two twins' clocks.
All of this was worked out by the Danish physicist Christian M\o ller in 1943 using general relativity, though he didn't realize (apparently) that the result was exact. A French physicist, Henri Arzèlies, went through it and showed indeed that the resolution was exact. In fact, general relativity is not needed at all: the equivalence principle and gravitational time dilation are all that are required.
Reference: https://www.physicsforums.com/threa...time-dilation-is-due-to-acceleration.1051866/
  • #37
So are you saying that Sabine's video is wrong?
  • #38
Why do you KEEP asking that same question? This is beginning to look like you are just trolling us.
Forget the damn video and study some actual physics.
  • Haha
  • Love
  • #39
As @phinds said, this question has already been answered. Her statement is wrong, or at least not clearly right.
It is time to move on. We are a physics education site, not a YouTube video criticism site. So if this thread is intended to help you learn physics then please move on to some of the substantive responses about the physics that you have received but ignored.
  • #40
As others already mentioned, for example her statement at 18:00 is wrong.
On the other hand, I like her visualization of the reciprocity of time dilation at 09:51 with help of the hyperbolas of equal proper time in the animated Minkowski diagram.
  • #41
Thank you Dale. I will likely be reaching out to Sabine and citing this thread, asking her to please correct her errors. I will be citing Dale the physics expert from physicsforums.com if that is OK with you--thank you:
Her statement is wrong, or at least not clearly right. -Dale, physics expert from physicsforums.com
  • Sad
  • #42
What is wrong with you? Seriously?
  • #43
So I guess that is a clear indication that you are not interested in learning physics, just getting a review.
Feel free to cite me. My statements are a matter of public record.
@ all participants, further posts with no physics content will be deleted. Particularly posts only about the video
  • #44
I would like to learn the proper physics for this topic. Please do share.
Vanadium 50 said:
If it's to learn relativity, the best way is to stop watching Youtube videos, pick up a copy of Taylor and Wheeler and start working through it.
  • #45
What physics is Sabine getting wrong? What is the best and most constructive way we can offer a correction so she can better help with the greater mission of teaching proper physics? What should have Sabine said in her video.
Read the thread, why are you still asking this?
If your mission is to correct pop sci videos on youtube, you are on a pretty long mission...
  • #46
Would it be better to learn physics from a Ph.D. or professor or textbook, or an internet forum where most folks don't share credentials, research publications, or institutions. Please let me know the best way to learn physics,
The best way to learn physics is through a traditional physics course.
A second good approach is with a textbook (Taylor and Wheeler has already been recommended), but for that it is important to discipline yourself to work the practice problems in the textbook, not just read the material. More learning occurs in practice problems than in passive reading.
Online forums, like this one, can only supplement this kind of learning. We cannot replace it nor serve as a substitute.
Research publications are a good place to learn advanced concepts, but not the basics. They assume that the reader has already mastered the textbook material.
PopSci videos and books are actively harmful.
Might you have a Ph.D.?
I do, as do many of the primary contributors to this forum. I am also a full time physics educator professionally.
You say that "(Sabine's) statement is wrong, or at least not clearly right." What physics is Sabine getting wrong?
I explained this in detail in my first post to you, which you glossed over in preference for harping on the video. Please take the time now to read my substantive response and ask follow up questions about the physics.
https://www.physicsforums.com/threa...-is-due-to-acceleration.1051866/#post-6877408
  • #48
Time(*) to close this thread.
(*) At least in my frame...
  • Haha
  • · Replies 18 ·
  • · Replies 27 ·
  • · Replies 54 ·
  • · Replies 42 ·
  • · Replies 18 ·
  • · Replies 46 ·
