Sampling Frequencies: f1, f2, f3 with fs=1000Hz
  • Thread starter Thread starter electronic engineer
    Frequencies Sampling
The discussion focuses on the analysis of signal frequencies f1=18 Hz, f2=510 Hz, and f3=1100 Hz sampled at fs=1000 Hz and fs=1002 Hz. It is established that f2 and f3 exceed the Nyquist Frequency (fc=500 Hz), leading to aliasing. The formula used for sampling is SΔ(v)= fs∑(S(v-n*fs)), which is applied to determine the sampling results for each frequency. The user seeks clarification on how to interpret the sampling results for both sampling frequencies.
  • Understanding of Nyquist Theorem and Nyquist Frequency
  • Familiarity with signal processing concepts
  • Knowledge of sampling theory and aliasing
  • Proficiency in using mathematical formulas for signal analysis
  • Study the implications of aliasing in signal processing
  • Learn about different sampling frequencies and their effects on signal integrity
  • Explore the use of the Fourier Transform in analyzing sampled signals
  • Investigate advanced sampling techniques to mitigate aliasing
Students and professionals in signal processing, electrical engineering, and anyone involved in analyzing or designing systems that require accurate signal sampling and interpretation.
electronic engineer
We have the following signal frequencies:
f1=18 Hz, f2=510 Hz, f3=1100 Hz
when using the sampling frequency fs=1000 Hz.
how would these signals be like?
my question is if I could use the same formula stated below for all the frequencies f1,f2,f3.. because the second and third ones are above the Nyquist Frequency fc=fs/2=500 Hz so there would be aliasing in this case.
and what about the graphs for these samplings?
when using another sampling frequency fs=1002 Hz
and here also would be the same questions.
I used the formula:
$$ S_{\Delta }(v)= f_{s}\sum_{n=-\infty}^{+\infty}(S(v-n*f_{s})) $$
for the first frequency f1= 18 Hz I had:
$$ S_{\Delta}(18)=1000\sum(S(18-n*1000)) $$
where $$ n=-\infty $$ to $$ +\infty $$
Do you mean, for each actual frequency, what is the lowest frequency that could yield the same sampling results?
No i mean for each actual frequency wha are the sampling results for fs=1000 Hz and then for fs=1002 Hz.
